what to look for when buying a car
Old Aug 29, 2004 | 11:56 AM
91ls-v's Avatar
Default what to look for when buying a car
well yeah my friend is buying a 90 integra..what should we look out for?
The owner said the timming belt snapped before but it has been fixed and after the belt broke the car has been running bad...but i test drove it and it was fine to me... The car has also been sitting for around 3 years. He said the fuel injection was messed up that is why he never drove it but there are no signs of it.
Old Aug 29, 2004 | 12:00 PM
StrtMeUp01's Avatar
Default Re: what to look for when buying a car (91ls-v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ls-v &raquo;</TD></TR><TR><TD CLASS="quote">well yeah my friend is buying a 90 integra..what should we look out for?
The owner said the timming belt snapped before but it has been fixed and after the belt broke the car has been running bad...but i test drove it and it was fine to me... The car has also been sitting for around 3 years. He said the fuel injection was messed up that is why he never drove it but there are no signs of it.</TD></TR></TABLE>
You should look for a 94 or newer...JMO
Old Aug 29, 2004 | 12:01 PM
bdkrma's Avatar
I have a 90 integra, as well as a bridge in NY I can sell you
Old Aug 29, 2004 | 12:12 PM
G-bonic's Avatar
Hijacked
get the VIN# and get the title of the car. then check for oil leaks underneath then check for any knocking noise or squeeking and aski him too if it burn too much oil or ask him if he adds up oil once in a while or every other week or wut and how much he adds up...
Old Aug 29, 2004 | 12:22 PM
StrtMeUp01's Avatar
If you dont know what or how to check for leaks or other problems with the car, just spend $25 and take it to Jiffy Lube and let them inspect it, if the car has a rear main seal leak, its a pain in the rear to fix, chances are youd take it to a mechanic and he would charge alot, unless you want to take apart the transaxel and flywheel/driveplate and replace the ring seal.....
Old Aug 29, 2004 | 02:38 PM
93GSRB17's Avatar
Sounds sketchy!!! BEWARE
Old Aug 29, 2004 | 02:42 PM
xprohx's Avatar
I think too much
Default Re: what to look for when buying a car (93GSRB17)
carfax is your friend
teacherman
Apr 21, 2011 02:35 AM
theheilious
Sep 6, 2008 04:42 AM
Shaguar47
May 27, 2007 04:22 AM
DeDonDeRosa
Apr 22, 2005 03:39 AM
