valve spring question
Old Aug 29, 2004 | 07:38 AM
93lsd's Avatar
Default valve spring question
i am currently running a comp cam valves springs and tit retainers with dual valves on intake and single on the ext along with the comp stage 2 cams, my question is i am going too be using skunk 2 stage 3 cams and wondering if it would be alright if i was too use a stock inner spring on the ext for a little more protection, and would it mess anything up
Old Aug 29, 2004 | 08:26 AM
b19coupe's Avatar
Default Re: valve spring question (93lsd)
ITR intake outers and Portflow inners all the way around.
Old Aug 29, 2004 | 12:49 PM
93lsd's Avatar
Default Re: valve spring question (b19coupe)
but i dont have portflow i have comp can i just use the b16 inners with the comp ext outers
Old Aug 29, 2004 | 01:03 PM
b19coupe's Avatar
Those valve springs will coil bind with Skunk Stage 3 cams. The ITR/Portflow combo is an economical (read cheap) way to go.
Old Aug 29, 2004 | 01:31 PM
LSVTEC 91 Civic's Avatar
Banned
Cheap is not a good idea when you're talking about your valve springs, you don't want to break them, i've been through the headache. Get a set of crowers, worth the money.
408EJ1
Mar 28, 2011 05:40 PM
ls_bitik
Mar 17, 2008 05:55 PM
hondadriver
Sep 11, 2006 09:55 AM
Amped
Aug 30, 2006 04:33 PM
Fly1865
Aug 15, 2005 07:35 PM
