Why no VTEC w/ VAFC II?
Old Aug 28, 2004 | 10:07 PM
HYREV2NR's Avatar
Default Why no VTEC w/ VAFC II?
I know for a fact it's wired correctly but I can't seem to figure it out. It shows that XX-over @ the set RPM's & the light goes from green to red but the VTEC isn't engaging! The instruction are a bit confusing & I had a VAFC I before this one. On the version I you just hook it up & it works. But on the version II I'm not sure what I'm doing wrong or, does this thing need to be programmed in some way to make the VTEC work? It has alot more features than the old one & would really like to use it but I can't quite figure it out. Any info would be greatly appreciated. Thanks
Old Aug 28, 2004 | 10:53 PM
GsrGilbert's Avatar
Default Re: Why no VTEC w/ VAFC II? (HYREV2NR)
i do know that u have to set the engagement point if it didnt come prebuilt i dont remember if mine did or not
Old Aug 28, 2004 | 10:58 PM
HYREV2NR's Avatar
Default Re: Why no VTEC w/ VAFC II? (GsrGilbert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrGilbert &raquo;</TD></TR><TR><TD CLASS="quote">i do know that u have to set the engagement point if it didnt come prebuilt i dont remember if mine did or not</TD></TR></TABLE>Either I don't overlooked something in the unit itself or the unit is falty. I did set the eng point @ 3100 RPM's just to see if it would work but it didn't. Thanks anyway.
Old Aug 28, 2004 | 11:09 PM
ITR 2K's Avatar
You have to set it for what kind of car first. Set it for a 4 cylinder. Same **** happened to me.
Old Aug 28, 2004 | 11:20 PM
HYREV2NR's Avatar
Default Re: Why no VTEC w/ VAFC II? (ITR 2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 2K &raquo;</TD></TR><TR><TD CLASS="quote">You have to set it for what kind of car first. Set it for a 4 cylinder. Same **** happened to me.</TD></TR></TABLE>I've done that also. I'm still trying to figure out what 3 different settings of VTEC are for. I might just put the VS I back in till I can make some sense of this thing!
Old Aug 29, 2004 | 03:59 AM
Syner-G-Racing LLC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">Either I don't overlooked something in the unit itself or the unit is falty. I did set the eng point @ 3100 RPM's just to see if it would work but it didn't. Thanks anyway.</TD></TR></TABLE>
after you do the intial setup your suposed take it for a quick run to engage the vtec so the vafc can learn the parameter of the factory settings. with out doing this it doesnt have the knowledge to correct it. intialize the settings, do the setup, do you tps test and your map test and then turn it off to store those settings then start it up take it for a run to engage the vtec then you can change the engagment points with the controller. (the lights change and the vafc show it engaging because its set in the controller but it doesent know where the ecu engages.
Old Aug 29, 2004 | 04:02 AM
Default Re: Why no VTEC w/ VAFC II? (Syner-G-Racing)
do you have the instructions or the installation manual. if so follow the setup procedures exactly (use the installation manual to figure out which vtec setup, tps voltage and cyl ect.) any questions let me know.
Old Aug 29, 2004 | 05:46 AM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">
after you do the intial setup your suposed take it for a quick run to engage the vtec so the vafc can learn the parameter of the factory settings. with out doing this it doesnt have the knowledge to correct it. intialize the settings, do the setup, do you tps test and your map test and then turn it off to store those settings then start it up take it for a run to engage the vtec then you can change the engagment points with the controller. (the lights change and the vafc show it engaging because its set in the controller but it doesent know where the ecu engages.</TD></TR></TABLE>
Words of wisdom.
Old Aug 29, 2004 | 10:25 AM
HYREV2NR's Avatar
Thanks a bunch guys! I had no idea this one would be so finiky.
Old Aug 29, 2004 | 11:47 AM
Combustion Contraption's Avatar
its finiky cuz its better.
p.s. save up and go with hondata.
Old Aug 29, 2004 | 04:47 PM
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">its finiky cuz its better.
p.s. save up and go with hondata.</TD></TR></TABLE>
good advice....my vafc II is now a realy expensive digital tach since I got my hondata s200b.
Old Aug 29, 2004 | 08:11 PM
TurboTeG4's Avatar
Default Re: (Syner-G-Racing)
With my vafc hooked up to my gsr it would give a map cell and all the wires was hooked up right. So I took it off, but that was the older model one, I dont know about the new model.
Old Aug 29, 2004 | 09:18 PM
HYREV2NR's Avatar
Default Re: (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">With my vafc hooked up to my gsr it would give a map cell and all the wires was hooked up right. So I took it off, but that was the older model one, I dont know about the new model.</TD></TR></TABLE>I'm about ready to sell the darn thing & just wait on Hondata. Or use it in the car for eye-candy.lol So tell me, what was the difference when you swapped to Hondata?
Old Aug 29, 2004 | 10:32 PM
Default Re: (HYREV2NR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">I'm about ready to sell the darn thing & just wait on Hondata. Or use it in the car for eye-candy.lol So tell me, what was the difference when you swapped to Hondata?</TD></TR></TABLE>
dont know I havent installed it yet still waiting for the rest or my setup. here are some pics though. https://honda-tech.com/zerothread?id=974988.
Old Aug 30, 2004 | 12:02 AM
TurboTeG4's Avatar
I put my hondata in and burned my first basemap, and guess what my car ran haha
But its a p29 with a gsr program so what happens with the 2ndary butterlys/?
Old Aug 30, 2004 | 01:33 AM
DC5RK20A's Avatar
Is the VTEC set for VTEC 1? There are 3 different types of VTEC, on the ITR it is type 1. Make sure it is set for that. That could be one of the problems maybe.
Old Aug 30, 2004 | 01:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">I put my hondata in and burned my first basemap, and guess what my car ran haha
But its a p29 with a gsr program so what happens with the 2ndary butterlys/?</TD></TR></TABLE>
so how did it run? Im not sure what will happen with the secondary butterflys...I guess they just sit there. maui huh i live on oahu
dx2sicrx
Engine Management and Tuning
May 19, 2008 10:21 AM
bchomka
Oct 31, 2004 08:48 AM
willywonka
Aug 11, 2003 01:15 PM
fxrob
Jun 12, 2003 08:59 PM
ludespeeder
Jun 25, 2002 04:07 PM
