pls help...my rpm gauge doesnt work .......
Old Aug 28, 2004 | 04:52 PM
jpangeles's Avatar
Default pls help...my rpm gauge doesnt work .......
hi....i just did a ls/vtec into my crx....for some reason the rpm doesnt work...setup is 92 block, 98 gsr head, jdm s1 tranny, pr3 w/ mugen chipped.....also my idle is low..how can i raise up my idle? thanks everyone for reading my post...
Old Aug 28, 2004 | 07:08 PM
jpangeles's Avatar
Default Re: pls help...my rpm gauge doesnt work ....... (jpangeles)
anyone?
Old Aug 28, 2004 | 07:41 PM
Frog's Avatar
Did your S1 come with a mechanical or electric VSS? If it came with a electrical, did you change your cluster?
Old Aug 28, 2004 | 08:42 PM
jpangeles's Avatar
Default Re: pls help...my rpm gauge doesnt work ....... (Frog)
i'm not sure if does the jdm b16a cable tranny 89-91 s1 is the tranny code...if its electrical can i just used mine from my old crx tranny?
Old Aug 29, 2004 | 08:46 PM
Frog's Avatar
Ok, well your stock cluster has a thick black cable which runs from the back of your cluster, through the firewall to the tranny. If your JDM S1 tranny uses an elctrical VSS, which I think they all do, you will either need to install a JDM sir cluster, or swap the VSS like you mentioned. Have a look at your tranny, facing the fire wall, it will be on the right hand side of the rear tranny mount( i think).
good luck
Old Aug 29, 2004 | 08:54 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frog &raquo;</TD></TR><TR><TD CLASS="quote"> If your JDM S1 tranny uses an elctrical VSS, which I think they all do</TD></TR></TABLE>
Nope. My JDM S1 tranny has the cable.
Old Aug 29, 2004 | 10:09 PM
Frog's Avatar
Default Re: pls help...my rpm gauge doesnt work ....... (eda6 hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">
Nope. My JDM S1 tranny has the cable. </TD></TR></TABLE>
there you go..... shows you how much I know
integrabois1991
Texas -OK -LA (Sales)
Oct 31, 2012 04:19 AM
civic889802
12
Jan 8, 2006 10:15 PM
FrOsTwHiTeDC4
Oct 12, 2005 02:31 PM
PhatHardy
Jan 31, 2003 04:55 AM
