which bearings?
ok, that is what i thought. the only thing that threw me off was when i was ordering it had the 2 different options; b18c1/c5 and b18a/a.
i think they are the same though, however someone PLEASE correct me if i am wrong.
The bearings are not the same ! the Noch are on diffrent sides and the width of the b18c1/c5 smaller than the b18a/b bearings . thats for rods and the mains should be the same but i think the c1/c5 width are smaller too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radeon »</TD></TR><TR><TD CLASS="quote">The bearings are not the same ! the Noch are on diffrent sides and the width of the b18c1/c5 smaller than the b18a/b bearings . thats for rods and the mains should be the same but i think the c1/c5 width are smaller too.</TD></TR></TABLE>
thanks good info.
anyone else confirm this, bump.
thanks good info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass »</TD></TR><TR><TD CLASS="quote">get acl
..... thats not the topic.
i have acl bearing for a b18a/b.
now go back and read the topic.
</TD></TR></TABLE>..... thats not the topic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">
now go back and read the topic.</TD></TR></TABLE>
oh ok.. i think they are the same except the trust washers are diff ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Main bearings are the same. Rod bearings are different. You MUST align bore the mains when using mains from another block. </TD></TR></TABLE>
ok if main bearings are the same then that is all i have to worry about because it is an ls block except for the gsr block girdle.
ls crankand rods. and the block is being bored and honed so that is not a worry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote"> and the block is being bored and honed so that is not a worry</TD></TR></TABLE>
Boring and honing the cylinders is not the same thing as align boring the mains.
Have the mains align bored!
Have the mains align bored!</TD></TR></TABLE>
