*** FS: Clutchmasters 6-puck for Cable B-Series, EG A/C stuff, DC engine mounts,
Old Aug 28, 2004 | 12:24 PM
dlric's Avatar
Default *** FS: Clutchmasters 6-puck for Cable B-Series, EG A/C stuff, DC engine mounts,
All stuff for sale - will accept any <U>reasonable</U> offer!
*Clutchmasters Stage 4 6-puck Springless Clutch + Pressure Plate for Cable B-series (smaller spline) - SOLD!
*EG A/C system - all the underhood components. I pulled this out of my '93 Del Sol S. It was working perfectly at the time - I just wanted to shed some weight.
Includes compressor, condensor, all lines, all wiring, everything under the hood. Accepting all reasonable offers on this. Willing to ship.
*DC Rear Tranny "T" Mount Bracket
Accepting B.O. on this.
*DC Timing Belt Side Engine Mount Bracket
*DC Driver Side Engine Mount
Accepting B.O. on this as well.
*EG Test Pipe 2" Inner Diameter
The test pipe has both flanges. The 3-bolt B-pipe end flange is welded on. The other flange that bolts to a header is a bracket flange that slides around. When I took the pic, I should have moved the header bracket flange to the correct end of the pipe. This test pipe bolted to my gsr exhaust manifold and usdm type-r exhaust manifold perfectly. There is no O2 bunge welded on so I don't know if it would work for obd2 but it worked for my obd1 setup. Accepting B.O. on this.
I have tons of vouches - Tbone, keithv, sonic, berkel, owen_the_sowboy, cyrk007, jcushing, gamby, etc.
Thanks!
Modified by dlric at 11:15 AM 1/5/2005
Old Aug 28, 2004 | 01:18 PM
dlric's Avatar
Default Re: *** FS: Clutchmasters 6-puck for Cable B-Series, EG A/C stuff, DC engine mounts, (dlric)
bump
Old Aug 28, 2004 | 06:12 PM
dlric's Avatar
Old Aug 29, 2004 | 07:03 AM
dlric's Avatar
upppp
Old Aug 29, 2004 | 05:22 PM
dlric's Avatar
ttt
Old Aug 30, 2004 | 05:12 PM
dlric's Avatar
must...get...rid...of....stuff
Old Aug 31, 2004 | 06:55 AM
dlric's Avatar
i know someone wants this stuff
Old Aug 31, 2004 | 05:04 PM
dlric's Avatar
izup
Old Sep 1, 2004 | 07:30 AM
dlric's Avatar
9/1/04 where did the summer go
Old Sep 2, 2004 | 05:26 AM
dlric's Avatar
Old Sep 4, 2004 | 08:15 AM
dlric's Avatar
if no one takes this clutch then i'll have to find a cable tranny to use it with
Old Sep 5, 2004 | 01:13 PM
dlric's Avatar
up
Old Sep 6, 2004 | 03:30 PM
dlric's Avatar
i know someone wants a/c
Old Sep 8, 2004 | 04:14 AM
dlric's Avatar
ttt
Old Sep 9, 2004 | 11:32 AM
dlric's Avatar
ttt
Old Sep 12, 2004 | 04:47 PM
dlric's Avatar
buy the clutch or i'll be forced to buy a cable tranny to use with it and drop it in my crx
Old Sep 15, 2004 | 04:01 PM
dlric's Avatar
you guys really want me to put my setup in the crx huh
Old Sep 19, 2004 | 06:51 PM
dlric's Avatar
must sell
Old Sep 25, 2004 | 02:15 PM
dlric's Avatar
this stuff has to go...i just did a swap so i have a bunch more extra stuff
Old Sep 28, 2004 | 08:02 AM
dlric's Avatar
up up
Old Sep 28, 2004 | 08:58 PM
dlric's Avatar
extra stuff taking up space in my basement
Old Sep 29, 2004 | 12:46 PM
sticky_racing's Avatar
i need the timing belt side engine mount bracket and the drivers side engine mount.
get back to me cause i need this stuff asap.
Old Sep 29, 2004 | 06:49 PM
dlric's Avatar
Default Re: (sticky_racing)
pm'd
Old Oct 2, 2004 | 02:42 PM
cyrk007's Avatar
Default Re: (dlric)
bump for someone i stallown3d in poker today... haha
Old Oct 6, 2004 | 10:19 AM
dlric's Avatar
Default Re: (cyrk007)
i see your bump...and i raise you another
