Stage 2 Crower cams ?
Old Aug 28, 2004 | 10:29 AM
firthy's Avatar
Default Stage 2 Crower cams ?
What is the difference between the Crower Stage 2 cams, one with stock idle lobes and the other Stage 2 cams without stock idle lobes ?
What difference will this make to performance and everyday driving ?
Old Aug 28, 2004 | 10:34 AM
Rick Solis's Avatar
Default Re: Stage 2 Crower cams ? (firthy)
The primary lobes on the 63422-2 are a little bigger than the 63422A-2... It makes better low and mid but idles a little worse than stock... Still relatively stock idle though... I know several running them with no problems at all...
The problem with the 63422A-2 the th transition into VTEC... Its not quite as smooth (tuning wise) as the 63422-2
Old Aug 28, 2004 | 10:42 AM
yeahdudebrown's Avatar
Default Re: Stage 2 Crower cams ? (Rick Solis)
https://honda-tech.com/zerothread?id=939641
Old Aug 29, 2004 | 10:31 AM
firthy's Avatar
So the 63422-2 are the ones to go for as they give better low down power, but what is the idle like on these and are they okay for driving around town with lots of stopping and starting ?
Old Aug 29, 2004 | 11:29 AM
LudeyKrus's Avatar
Be a man; use the ones w/ the bigger idle lobes.
175Shot4Door
Feb 11, 2009 04:56 PM
iMPoRT GeeK
Jul 29, 2007 12:32 AM
dand39
Jan 6, 2005 12:44 AM
Calavera
Mar 29, 2003 12:31 PM
Mover
Nov 30, 2002 06:38 PM
