k20a3: Upgrade WHAT for higher revs?
Old Aug 28, 2004 | 01:59 AM
Civic Hatch Boy's Avatar
New User
Default k20a3: Upgrade WHAT for higher revs?
What should be upgraded to safely rev to 7700?
Valve springs/retainers?
Pistons & Rods?
Around how much will this cost?
Old Aug 28, 2004 | 05:46 AM
rsxmachine's Avatar
Default Re: k20a3: Upgrade WHAT for higher revs? (Civic Hatch Boy)
retainers and valve springs definitely for the long term. everything else should be ok
you can get the ones that are used on the RSX-S/S2K for around 200 plus shipping, plus installation (which is kinduva pain). I can provide part #s if you want
or, what have some have done is pick up a used set of valve springs from an RSX-S that has upgraded to Toda kit
Old Aug 28, 2004 | 06:06 AM
Kal's Avatar
Kal
you'll need the oil squirters and better oil pump found in the a2 and a.
but why would you want to rev it so high? there's no point.
Old Aug 28, 2004 | 02:19 PM
rsxmachine's Avatar
Default Re: k20a3: Upgrade WHAT for higher revs? (Kal)
he's asking because 7700 is the rev limit on the Hondata reflash for EP3.
won't need oil squirters... but a few EP3 people have had problems with retainers breaking or a valve spring shifting out of place.
Old Aug 28, 2004 | 08:16 PM
Battle Mike's Avatar
Default Re: k20a3: Upgrade WHAT for higher revs? (rsxmachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxmachine &raquo;</TD></TR><TR><TD CLASS="quote">he's asking because 7700 is the rev limit on the Hondata reflash for EP3.
won't need oil squirters... but a few EP3 people have had problems with retainers breaking or a valve spring shifting out of place.</TD></TR></TABLE>
ouchy, I need to upgrade mine...I'm running a jrsc with that rev limit...what is the part number you mentioned above?
Old Aug 28, 2004 | 09:21 PM
steven975's Avatar
Default Re: k20a3: Upgrade WHAT for higher revs? (02SilverSiHB)
can the A3 even make decent torque that high? Wouldn't you need cams with a higher lift?
Regardless, a Type S head would definitely help the high end torque as the A3 has the econo-VTEC (same as the HX VTEC-E actually), and only on the intake. The Type S head has true VTEC on both intake and exhaust.
Old Aug 29, 2004 | 05:47 AM
Default Re: k20a3: Upgrade WHAT for higher revs? (steven975)
my torque and hp keeps climbing all the way to 7700, but then again, I have a jrsc on it.
Old Aug 29, 2004 | 10:08 AM
BaNAnABoAt689's Avatar
B A N N E D
From: los angeles, Eagle Rock, CA, united states of america
losses power pass or around 7700, no point in going higher unless boosted or a built A3 which i doubt cause nothing can go in our engines.
89efhatchy
Mar 7, 2014 04:06 AM
turbolshatch
Oct 5, 2007 08:43 AM
Dominic-CTR
Dec 6, 2004 12:28 PM
af97civic
Mar 24, 2004 10:14 AM
WONG FRIED RICE
Sep 3, 2001 11:24 AM
