My H22A1 all motor setup.
Old Aug 27, 2004 | 07:54 PM
H22A-AllMotor's Avatar
Default My H22A1 all motor setup.
Skunk2 Stage 3 Camshafts
H20 Cranshaft
Valve Springs & Retainers
JE Pistons & piston rings
JE bars
Ported & Polished head
Skunk2 intake manifold
AEM fuel rail
550cc Fuel Injectors
HKS head gaskets
NGK spark plugs & plug wires
Skunk2 adjustable cam gears
Skunk2 intake
DC Sports 4-2-1 Ceramic header
DC Sports stainless steel catback exhaust
Pro lite 9lb. flywheel
Puck-six stage4 clutch
ACT pressure plate
Drilled & Slotted brake rotors
Fluidyne radiator
MSD ignition
Front & Rear strut tower bars
Rear lower tie bar
NT 450 Nitto Stickies(tires)
Hondata s200.
Polished block
Heat clayed head.
New fuel lines
I just thought I'd post my setup here to see if anyone may know some problems that could occur, and help me with fixing them. Thanks.
Old Aug 27, 2004 | 08:43 PM
4drsedaneg's Avatar
Default Re: My H22A1 all motor setup. (H22A-AllMotor)
whats with the monster injector for a straigh up all motor set up, u would go a little smaller with them unless you plane on using ITB's or something, and whats a h20 crankshaft??
Old Aug 27, 2004 | 09:28 PM
Robb's Avatar
Default Re: My H22A1 all motor setup. (4drsedaneg)
No Skunk2 stage 3, doesnt exist
Whats an h20 crank, and what the heck is a heat clayed head? And JE bars, whats that?
Old Aug 28, 2004 | 12:10 AM
WhiteGSR95's Avatar
http://www.wiredspeed.com/item...q=&Tp= <---skunk2 stage3 cams
Old Aug 28, 2004 | 12:42 AM
jdmh22eg's Avatar
any dyno numbers?
Old Aug 28, 2004 | 05:27 AM
IntegraB18's Avatar
Default Re: My H22A1 all motor setup. (Robb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robb &raquo;</TD></TR><TR><TD CLASS="quote">No Skunk2 stage 3, doesnt exist
lol
Old Aug 28, 2004 | 06:07 AM
Rick Solis's Avatar
Default Re: My H22A1 all motor setup. (IntegraB18)
Skunk2 Stage 3 for the H22 DOES NOT exist... The stage 3 became the stage 2 early last year after they put the R&D on the H cams on what seems to be a permenant hold to better "consentrate on other things"
By the H20 I believe he means the crankshaft from the F20B
Old Aug 29, 2004 | 07:51 AM
Default Re: My H22A1 all motor setup. (Rick Solis)
Lol sorry about the slip of the fingers, I meant stage 2 cams, and by bars I meant rods... Had a little bud light in me
TMax173629
Jun 14, 2008 02:51 PM
TMax173629
Jun 14, 2008 11:02 AM
TMax173629
Jun 14, 2008 06:46 AM
B18c1EKCpe
Jul 30, 2005 03:14 AM
RosebloodSol
Mar 4, 2002 07:24 PM
