d16y8 camshaft choice
Old Aug 27, 2004 | 06:19 PM
lmiguelvv's Avatar
Default d16y8 camshaft choice
what are some good pair of camshaft for a d16y8
Old Aug 27, 2004 | 06:56 PM
chad's Avatar
Moderator
Default Re: d16y8 camshaft choice (lmiguelvv)
if you dont' know you only have one cam in your engine then maybe you shouldn't be messing with it!!!
Old Aug 27, 2004 | 07:37 PM
murmur9's Avatar
Default Re: d16y8 camshaft choice (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">if you dont' know you only have one cam in your engine then maybe you shouldn't be messing with it!!!
HAHAHAHAHA I agree with the guy above. Its a SOHC...not DOHC,
Just leave it like it is....dosn't seem like you would even know what the camshaft is if you seen it. not to mention that the **** needs to be tq'ed down. dont **** up something that already works unless you know what to do.
Old Aug 27, 2004 | 07:43 PM
AGENT 99's Avatar
Default Re: d16y8 camshaft choice (murmur9)
I'll give you a useful answer since apparently nobody else here will. Yes, you only have one cam hence the sohc engine. The cam you pick will determine weather or not you need to upgrade your valve train (valve springs and retainers). Check out Crower and Zex cams. They seem to be the most popular. Some tuning may be required after the install to keep you idle in check. If you have any doubts, let a shop do it for you.
Old Sep 6, 2004 | 05:05 AM
GoneToTheDarkSide's Avatar
Default Re: d16y8 camshaft choice (6gcivic)
internals for sale... d16y8 or d16z6 along with other parts
https://honda-tech.com/zerothread?id=962350
Old Sep 6, 2004 | 05:40 AM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmiguelvv &raquo;</TD></TR><TR><TD CLASS="quote">what are some good pair of camshaft for a d16y8</TD></TR></TABLE>
im so close to making my signature longer and quoting this
skaternak
13
Jan 12, 2010 10:33 AM
Lyle_57IAL
Apr 8, 2009 11:34 AM
EX-T
Dec 16, 2007 07:15 PM
Downey
Sep 30, 2002 07:08 AM
Sohc Driver
Apr 11, 2002 09:42 PM
