wiring/fuse box help
Old Aug 27, 2004 | 05:07 PM
antiJDM's Avatar
Default wiring/fuse box help
a lil back ground
i'm in the process of re-wiring my 91 dx hb. i will be using the engine and dash harness from my 88crx si to run my jdm b16 that was previously in my 88 si. after wrecking the 88, i sold the under dash fuse box, so i tried to use the box from the 91. i was having trouble matching up all the plugs, so i assumed i needed to use another fuse box. i went to the pick n' pull and snatched a fuse box from an 88hf, but when i get back, i find out that it is the EXACT same as the dx box.
so my question is.........do i need to stop being stubborn and go get a damn wiring diagram, or do i need an 88si fuse box?
Old Aug 27, 2004 | 07:47 PM
antiJDM's Avatar
bump for my friend who has been using my username
Old Aug 28, 2004 | 08:55 AM
antiJDM's Avatar
Old Aug 28, 2004 | 09:24 AM
vtecn8ive's Avatar
Default Re: (2thousandcivic)
well 88-89 CRX's had different underdash wiring compared to 90-91. Not sure if they connect differently at the fuse box or not. Probably do though. Whatever wiring you use underthe dash should determine what fusebox to get.
Old Aug 28, 2004 | 09:27 AM
antiJDM's Avatar
thanks much appreciated.
97dc2
Apr 4, 2007 06:40 PM
misledyouth_is_back
Dec 30, 2003 02:59 PM
