Hasport mounts with a b18c1 in an EF. What hood will clear the engine?
Old Aug 27, 2004 | 04:37 PM
BR's Avatar
BR
Default Hasport mounts with a b18c1 in an EF. What hood will clear the engine?
What hood are you b18c1 guys using on your EF's?? I am about done with my swap and I dont want to run into any problems with my hood/valve cover clearance.
What did you guys do to make it work??
Just for reference, I have an 89 hatch with the Hasport billet mounts.
Later,
BR
Old Aug 27, 2004 | 05:53 PM
limpy's Avatar
Default Re: Hasport mounts with a b18c1 in an EF. What hood will clear the engine? (BR)
i have heard thatyou can always put a few washers in the hood hinges to give you a little more clearance.
Old Aug 27, 2004 | 07:17 PM
JapJunkie's Avatar
Default Re: Hasport mounts with a b18c1 in an EF. What hood will clear the engine? (limpy)
Shouldnt it fit, if B16s fit, shouldnt GSRs?
Old Aug 28, 2004 | 02:19 AM
BR's Avatar
BR
limpy - I have been told the same thing. Cut out the underside of the hood and prop it up with the washers to give it proper clearance.
hondadict - The b18c blocks have a higher deck than the other b-series blocks and can cause headaches when trying to fit them in the engine bay of the civics.
I am not really interested in the SiR hood because I dont want to convert the whole front end to the JDM one, and I am not too keen on the ZC hood cause that bubble just doesnt do it for me, although I may just have to go with the ZC one in the end...
Later,
BR
Old Aug 28, 2004 | 03:49 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BR &raquo;</TD></TR><TR><TD CLASS="quote">What hood are you b18c1 guys using on your EF's??</TD></TR></TABLE>
The stock hood with part of the underside skeleton removed.
Old Aug 28, 2004 | 11:21 AM
BR's Avatar
BR
Default Re: Hasport mounts with a b18c1 in an EF. What hood will clear the engine? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
The stock hood with part of the underside skeleton removed.</TD></TR></TABLE>And you arent having any problems with the valve cover clearance?
Later,
BR
Old Aug 28, 2004 | 12:11 PM
X-Static's Avatar
just email or call hasport, they know alot more about theyre mounts than we do
i know they also have personal experiance with theyre kits.
Old Aug 28, 2004 | 01:45 PM
Rywire's Avatar
Default Re: Hasport mounts with a b18c1 in an EF. What hood will clear the engine? (X-Static)
There are a few options here. You can get a sir front end conversion, sir style hood for usdm front ends, or just cut your stock one. Thats what I did, I cut 2 "ribs" out of the hood on the driver side, above the valve cover.
Ryan
Old Aug 28, 2004 | 04:34 PM
bryant's Avatar
Default Re: Hasport mounts with a b18c1 in an EF. What hood will clear the engine? (droppedcrxsi)
If anyones interested I have a OEM metal ZC hood FS. PM me.
Old Aug 28, 2004 | 05:51 PM
BR's Avatar
BR
Default Re: Hasport mounts with a b18c1 in an EF. What hood will clear the engine? (Bryant)
I might look into that SiR hood for the US front end. Any tips on where to look for one of those??
I am going to try cutting my hood up first to see if that does the trick, but if it doesnt then I will be in the market for a new hood.
Later,
BR
Old Aug 28, 2004 | 07:47 PM
Frog's Avatar
From my experience with the HAsport billet mounts, the will not clear the USDM hood. Not even after you cut out the hood supports. I switched to a JDM front end after a month or so.
Old Aug 28, 2004 | 07:48 PM
X-Static's Avatar
ViS makes a SiR "style" carbon fiber hood for the USDM front end.
I have a ViS SiR hood for my JDM front end and the quality couldnt be any better. Im very satisfied.
Old Aug 28, 2004 | 07:58 PM
BR's Avatar
BR
Default Re: Hasport mounts with a b18c1 in an EF. What hood will clear the engine? (Frog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frog &raquo;</TD></TR><TR><TD CLASS="quote">I switched to a JDM front end after a month or so. </TD></TR></TABLE>
What did that end up running you??
Later,
BR
Old Aug 28, 2004 | 08:33 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frog &raquo;</TD></TR><TR><TD CLASS="quote">From my experience with the HAsport billet mounts, the will not clear the USDM hood. Not even after you cut out the hood supports. I switched to a JDM front end after a month or so.
Mine worked fine after a lil cutting.
Ryan
Old Oct 22, 2004 | 09:23 PM
spcrxracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BR &raquo;</TD></TR><TR><TD CLASS="quote">limpy - I have been told the same thing. Cut out the underside of the hood and prop it up with the washers to give it proper clearance.
Later,
BR</TD></TR></TABLE>
Fiberimages SiR style CF hood. SiR style for the USDM front end
Dark_Teg
20
Apr 16, 2009 10:59 AM
freedm
18
Jan 14, 2009 07:08 PM
krazyblurtzcrx
10
Sep 8, 2008 07:09 PM
*Boostwerks*
41
May 10, 2004 11:31 AM
Rywire
Mar 29, 2004 02:41 PM
