My build is over, install time
Old Aug 27, 2004 | 04:30 PM
97CTR's Avatar
Default My build is over, install time
finally got everything together and am ready to put my engine back in my car, and do some tuning. I'll try and post some pics. It feels so good to finally finish a build. Now its time to deal with the inevitable bugs.
List of what I've been up to:
b16b block
gsr crank balanced and micropoished by Benson machine
oem rod and crank bearings
81.5mm IB probe pistons compression around 12.5
IB ultralight I beam rods, arp 2000 rod bolts
ARP headstuds
cometic head gasket
new water and oil pumps, seals etc.
Portflow headwork, deshroud chambers, bronze valve guides, 3 angle, port and polish titanium retainers, and valvesprings
Type r valves
JunIII cams
Power enterprises timing belt
Golden eagle cam gears
RC 370 injectors
Hondata s200 w/datalogging, rom editor
PLX M-300 wideband
9lb kaiten kairu flywheel
clutchmasters stage 3
aem v2
hondata IM gasket
bisimoto header
driveshaft shop stage 1 axles
thats all I can remember now
now I need suspension and tires
Modified by 97CTR at 5:03 PM 8/28/2004
Old Aug 27, 2004 | 10:14 PM
Dyn0speed's Avatar
Default Re: My build is over, install time (97CTR)
cant wait to see how it turned out
how much did all of this cost u?
Old Aug 27, 2004 | 11:35 PM
OLM-02R's Avatar
post some #
Old Aug 28, 2004 | 08:04 AM
97CTR's Avatar
Default Re: (OLM-02R)
I haven't figured out the cost yet, hoping for around 220 to the wheels, we will see.
Inferno^
Sep 27, 2009 08:32 AM
supermeister
Apr 2, 2009 04:02 AM
hondaclassifieds
Mar 5, 2009 12:53 PM
Skunk2R
11
Oct 19, 2008 05:46 PM
theinfamouskonrad
Aug 26, 2005 10:16 PM
