is this good compression for turbo?
Old Aug 27, 2004 | 03:25 PM
hatchinprogress's Avatar
Default is this good compression for turbo?
ok i did a compression check on my dohc zc and this is what i got: #1) 195 #2)195 #3)195 #4)195 is this strong(good) enough for boostin 8-10 psi????
Modified by hatchinprogress at 5:29 PM 8/27/2004
Old Aug 27, 2004 | 03:26 PM
4drEF's Avatar
Keyboard Humorist
Default Re: is this good compression for turbo? (hatchinprogress)
Sounds like decent numbers.
Rings seem to be in OK shape.
What motor and mods?
Any changes to the "other" compression?
Old Aug 27, 2004 | 04:30 PM
BR's Avatar
BR
Those numbers look good to me.
Later,
BR
Old Aug 27, 2004 | 04:34 PM
more input plz
Old Aug 27, 2004 | 04:40 PM
BR's Avatar
BR
What more do you need to know??
The compression is good, and that proves that the engine seems to be strong still. Boosting it is going to tear it up a lot faster than just keeping it NA, but that is the nature of a honda with a snail attached to it.
If you really want to be sure that it is all going to go right then take the block to a machine shop and build it for boost so you know damn sure that it can handle it.
Later,
BR
Old Aug 27, 2004 | 05:08 PM
Default Re: is this good compression for turbo? (BR)
my bad br when i said more input plz i ment more opinions not as in i need you to describe it to me, sorry for the misunderstanding
Old Aug 27, 2004 | 05:19 PM
BR's Avatar
BR
Its all good
Later,
BR
Old Aug 27, 2004 | 06:56 PM
ttt
Old Aug 27, 2004 | 07:22 PM
ServiceAdvisor's Avatar
That sounds like a stout motor, Dohc ZCs vary from motor to motor. Mines about 190 across the board too and the motor is in decent shape still. - Darrell
pane93civhb
Apr 6, 2009 09:17 PM
Drizzo
Aug 16, 2005 02:00 PM
TehMoonRulz
May 16, 2005 01:15 PM
speedshift23
Oct 19, 2003 08:38 PM
s0liDyNe
Jul 19, 2003 10:24 PM
