Roll Bar Harness Mounting
Go directly to the TEAM Simpson, M&R and other websites and there is a picture of the setup in the catalog. If that fails, go to the wwww.nasaproracing website and see if you can find it in the CCR.
Otherwise the correct method is to use the type of harness that wraps around the round bar and is secured with the plates supplied. It is very important that you do this correctly. There is a version of the Autopower cage that has a piece of flat stock on the horizontal-DO NOT use this or allow the harness to come into contact with it. Good luck.
Powered by Honda
15
Mar 5, 2004 06:54 AM
AllMotorITR
Jan 30, 2002 02:56 AM
RATEDR
Jan 28, 2002 04:23 PM
