Mounted the T4/SC61 and Mini-Me today...
Old Aug 27, 2004 | 02:42 PM
*Boostwerks*'s Avatar
Default Mounted the T4/SC61 and Mini-Me today...
Needless to say, it is a damn tight fit.
I don't know how Cody expects people to do they're oil return line, but its going to be tough.
I'm going to have to run a soft line from a barbed fitting to the pan.
The Down pipe is also going to be a tight *** sqeeze, but shouldn't be too bad. The Tial WG was hitting my fan, so I unfortunetly had to relocate it to the front of the radiator.
Were gonna weld up the charge piping tommarow, and if time do the down pipe.
The goal is to have the car boosted and running well on low boost for a Race on the 19th at Bandimere.
Looks good tho!
Enjoi
Old Aug 27, 2004 | 02:46 PM
HXMan's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (Bryson)
THat turbo looks nice.
Old Aug 27, 2004 | 02:51 PM
AbaZ's Avatar
Clock the center section towards the pan a little bit and use a angled fitting off the return to aim at the pan. If you thinks that bad, you should see my buddy when he makes manifolds I think he forgets sometimes that oil returns are even used.
Looks good, curious on how she spools up
Old Aug 27, 2004 | 02:54 PM
TeStUdO's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (AbaZ)
Nice setup and nice Vband, good luck on the feed and return fittings. I think the angled fitting approach is a good choice.
FredoSP's Avatar
looks good bryson! I agree with clocking the center section of the turbo.
Good Luck.
Old Aug 27, 2004 | 04:47 PM
M.A.R.C.'s Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (FredoSP)
looking good bryson can't wait to see it in action
Marc
Old Aug 27, 2004 | 04:51 PM
D-Man's Avatar
I got all excited for a second...thought you mounting it on a D15
Old Aug 27, 2004 | 06:08 PM
Code Blue's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (TeStUdO)
angled fitting likes like it might be the best option for you
Old Aug 27, 2004 | 06:22 PM
Charles B.'s Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (Code Blue)
looks pretty good so far. good luck on finishing everything
Old Aug 27, 2004 | 06:38 PM
SOHC_MShue's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">I got all excited for a second...thought you mounting it on a D15 </TD></TR></TABLE>
haha me too
Old Aug 27, 2004 | 06:41 PM
Sinner's Avatar
I was looking for a sohc mini-me, blah isnt that called a frankiestin or some **** like that?
Old Aug 27, 2004 | 06:48 PM
turbo*s2k's Avatar
looks good!
Old Aug 27, 2004 | 07:06 PM
AbaZ's Avatar
Default Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">I was looking for a sohc mini-me, blah isnt that called a frankiestin or some **** like that?</TD></TR></TABLE>
I believe the manifold is called the "mini-me" made by lovefab.
The engine is what a 2.0l gsr?
Old Aug 27, 2004 | 07:20 PM
Boost Addict's Avatar
Default Re: (AbaZ)
Tight fit, but looks damn good.
Old Aug 27, 2004 | 07:51 PM
speeddave's Avatar
Default Re: (xPRELUDEx)
looks good i've got the same size turbo t4 w/ .58exh, i'm still debating what size wastegate to get, what made you go with the 38mm instead of 40+mm? just curious. good luck with her!
Old Aug 27, 2004 | 08:26 PM
tommyten's Avatar
where did you get that clamp for your turbo? I've been looking for one...
Old Aug 27, 2004 | 08:32 PM
wHOAlly's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling &raquo;</TD></TR><TR><TD CLASS="quote">where did you get that clamp for your turbo? I've been looking for one...</TD></TR></TABLE>
http://www.atpturbo.com/
Old Aug 27, 2004 | 08:53 PM
b16sedan's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (Sp00n'd Supra)
If you've taken the manifold off the car, is there any way you could take some good pictures of the collector for me? I'd appreciate it a ton
Old Aug 27, 2004 | 10:13 PM
macrosshn's Avatar
the son and the heir
Default Re: Mounted the T4/SC61 and Mini-Me today... (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">If you've taken the manifold off the car, is there any way you could take some good pictures of the collector for me? I'd appreciate it a ton </TD></TR></TABLE>
Check out http://www.lovefab.com, there's plenty of pictures there.
Old Aug 28, 2004 | 01:32 AM
liam821's Avatar
25 Year Member
Default Re: Mounted the T4/SC61 and Mini-Me today... (macrosshn)
damn you got it together JUST in time to give me a ride...
liam
Old Aug 28, 2004 | 01:43 AM
HybridKOOP's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (liam821)
Is someone other than Cody welding these manifolds?
Old Aug 28, 2004 | 08:18 AM
Turbocivic94's Avatar
Default Re: Mounted the T4/SC61 and Mini-Me today... (HybridKOOP)
that looks sick, are u forgetting u have a crx, everything is tight
Old Aug 29, 2004 | 06:28 PM
Haha...
thanks so much for the compliments(and parts; you know who you are ) guys!
It does look like I'm going to have to clock the center section for the oil drain to work. Its just far too close to the cross member when pointed down.
Liam, The car should be boosted a couple days before you get here. We should be able to take it on the 19th, and I'm going to see if I can use Chris (crxrocks's) slicks. Hes bugged me for years that I could use them, but I never have...haha.
I chose the 38mm mainly because I kept it from my boosted ZC setup. I was told it would do fine for low boost on the T4, so I kept it.
Old Aug 29, 2004 | 09:51 PM
Default Re: (AbaZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ &raquo;</TD></TR><TR><TD CLASS="quote">
The engine is what a 2.0l gsr?</TD></TR></TABLE>
Yup...
Old Aug 30, 2004 | 01:55 PM
liam821's Avatar
25 Year Member
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Haha...
Liam, The car should be boosted a couple days before you get here. We should be able to take it on the 19th, and I'm going to see if I can use Chris (crxrocks's) slicks. Hes bugged me for years that I could use them, but I never have...haha.</TD></TR></TABLE>
badass i cant wait.
