i need help
Old Aug 27, 2004 | 02:38 PM
beny's Avatar
Default i need help
I have a 2 ton floor jack and it only lifts 14 inchs. I am trying to lift front of the car by the front center jack point, but only the driver side wheel leave the ground.
Is that ok to lift one sidet using where the LCA connect to the cross member (two bolt) and put jackstand then lift the other side.
and is that jack point safe (where the LCA connect to the cross member) ?
thanks
Old Aug 27, 2004 | 03:11 PM
hatchi's Avatar
Default Re: i need help (beny)
yes that is ok. what are you trying to do?
TheDonOG
Sep 13, 2016 07:27 AM
IAluder95
Suspension & Brakes
Aug 7, 2008 11:13 AM
clutch33
Apr 14, 2004 07:49 PM
sohc00
Mar 22, 2004 05:15 AM
Skeeter7424
May 30, 2003 07:05 AM
