Disconcerting Event
I went out to start my CRX the other day and it wouldn't start. It would turn over, but not start. Its a DOHC ZC turbo. It had just rained, so that might have had something to do with it, it leaks like no other. I just went out today to start it and it cranked up fine, no CEL's, runs perfect. I checked the plugs, and they look good. Any ideas? I just dont want to be somewhere else when this happens.
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
moisture in the distributor, main relay, or anywhere along the electrical.
when and if it happens again check for main relay; put the key in run position, and listen for fuel pump priming. check for spark, ignitor, and or bad grounds along the way. double check ECU and CELs.
good luck
stan
good luck
stan
Tranny and engine ground look good. Battery ground was under water, so I punched some holes in the lowest area under water so it drains now. Someone else suggested the main relay. If it wasnt replaced with the swap then it has 138k miles on it. Maybe I should just go ahead and replace it anyway.
peteyparado
Feb 9, 2014 07:38 PM
kamakaze1
Jan 24, 2006 03:47 PM
