i'm a dumbass: stripped 10mm brake line --> brake hose bolt, what's next?
am i replacing the whole metal line? something tells me i am. just goes to show that you really should use a flarenut when working on that p.o.s, box wrenches will not do.
can i replace the bolt part and leave the line in place?
Should be able to, use a vice grips to get it off and out, just be sure not to screw up the connector.
Flare flare flare.... flare wrench (for next time)-- on your fuel filter too!
cut the hard line and put on a new connector, flare the end and connect the connector....
amateurs...
Actually I did this once long ago, but was able to save it before rounding it off.
amateurs...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">Flare flare flare.... flare wrench (for next time)-- on your fuel filter too!
amateurs...
Actually I did this once long ago, but was able to save it before rounding it off.</TD></TR></TABLE>
yeah, no ****.
so they do sell the connector separately? all i got from a friend with a parts CD is the brake pipe, from MC to RR...
amateurs...
yeah, no ****.
hondazccivic
Aug 21, 2008 11:41 AM
