bad ecu?
i keep getting a check engine light for vtec pressure switch. it can't be the switch because vtec engages and its wired up correctly. i tried reseting the ecu. once i put the negative batery wire back on i turn my key to the on position (without starting the car) and the same check engine light comes on. after i start my car i get a code 8 (tdc). when i start up my car while its cold it takes a while to crank up. i believe i have a faulty ecu. is there any way to test this out? steve from hmo said that i could mail it back to him and he would check it out but this car is my daily driver and it would be very hard to go a week or so without a car. any help would be very appreciated.
crookson speed
Feb 19, 2014 01:32 PM
Metal_SOL
Jul 16, 2002 10:23 PM
