Cooling Fan Issue
Old Aug 27, 2004 | 11:27 AM
scrubachu's Avatar
Default Cooling Fan Issue
ok, my cooling fan has stopped working. no, its not the AC fan. i have gone through the diagnostic in the manual and it leads me to "a broken wire" meaning, im guessing either the power or the ground has been cut or burned through, etc, but one of those wires is no longer connected at some point in the harness. the fan works when i hook it up to the batery, as does the relay, so i know those arent the issues. im guessing it could be the sensor, but i dont want to buy a new sensor if i dont have to. i may try to run a wire from the ecu directly to the power wire of the sensor and then run another wire from the sensor to the relay, and a wire from the realy to the power of the fan, and then ground the fan to the frame. this would essentially go around the broken wire wherever it is. any other creative ideas? does anyone have a sensor they are selling?
on a side note, it worked fine for a long time after my swap, so i know its not that. i switched the wire and pin already when i first swapped the motor.
Old Aug 27, 2004 | 12:20 PM
Crazydave's Avatar
Default Re: Cooling Fan Issue (scrubachu)
sounds like a fan switch.
it's only $25 for a new one.
I'd try that rather than messing with wires for an hour
Old Aug 28, 2004 | 07:21 AM
scrubachu's Avatar
Default Re: Cooling Fan Issue (Crazydave)
ill try that. anyone else?
Schultzie
Dec 22, 2010 07:46 PM
NAV_GUNZ
Oct 14, 2008 09:36 PM
jvaughn
May 16, 2008 09:35 AM
FMIDRC Racer
Aug 27, 2005 12:22 PM
scrubachu
Aug 28, 2004 11:38 AM
