Oil Pan Gasket Leaking
Old Dec 4, 2001 | 03:52 PM
Cheap Bastard's Avatar
New User
Default Oil Pan Gasket Leaking
I found out today that my oil pan gasket is leaking oil and drips onto my header. I have 93k miles on my car and was wondering if this is a common condition on high milage Hondas?
The dealer wants to charge me $250 to change out the gasket! Perhaps I will leave it be. It seeps out very slowly.
Thanks,
CB
Old Dec 4, 2001 | 05:10 PM
RedlinedVTEC's Avatar
Default Re: Oil Pan Gasket Leaking (Cheap Bastard)
Bah just change it yourself really easy and the gasket won't run more than $6 . Just do it next time you change your oil. BTW put some honda bond around where the oil pump meets the block on the bottom of the block... same with the right side cover. Easy to fix save yourself $250. HTH
Old Dec 4, 2001 | 05:46 PM
ahcjar103's Avatar
Default Re: Oil Pan Gasket Leaking (RedlinedVTEC)
costs so much cuz they have to take off part of the header, which takes time, which is expensive as ****
Old Dec 4, 2001 | 06:06 PM
fsarfino's Avatar
Default Re: Oil Pan Gasket Leaking (ahcjar103)
yeah I would agree buy the helms and follow the outlined procedure make sure that you torque to the specs in the helms manual
I bet it will be the best $80.00 you spend
Old Dec 4, 2001 | 08:35 PM
ILOVEGIRLS's Avatar
Default Re: Oil Pan Gasket Leaking (dohcvtec16)
just change it out youreself. the pan is really easy to take out! just gottadrop out te header and youll see all the bolts on the bottom.
Old Dec 4, 2001 | 09:42 PM
New User
Default Re: Oil Pan Gasket Leaking (ILOVEGIRLS)
what about the prep work needed to get a new gasket on? do I need to scrape the gasket off and prep the surface for the new gasket?
Thanks,
CB
Old Dec 4, 2001 | 11:57 PM
Yeah just srape of any gasket that is left behind and then pop the new one on as I said a little honda bond here and there well help to ensure the seal is leak free. HTH
00civicsiboy
Apr 20, 2007 08:27 PM
blackdelslo
Jan 3, 2005 07:35 PM
NateTEG95
May 29, 2003 08:05 PM
ragejed
Jul 1, 2002 01:15 AM
drumsy
Feb 6, 2002 12:18 AM
