where can i get these seats beside jdmshit
Old Aug 27, 2004 | 04:41 AM
ironchef25's Avatar
Default where can i get these seats beside jdmshit
where can i get these beside jdmshit?
Old Aug 27, 2004 | 04:56 AM
Keebler's Avatar
Default Re: where can i get these seats beside jdmshit (ironchef25)
Japan
Old Aug 27, 2004 | 05:02 AM
schwanginpt's Avatar
i got mine from a different site.. but sadly the site isn't there anymore
ive seen some one ebay though. only other place i can think of.
Old Aug 27, 2004 | 05:10 AM
ironchef25's Avatar
Default Re: (schwanginpt)
how much should i pay for these seats.? its like 350 on jdmshit.
Old Aug 27, 2004 | 06:34 AM
$300 seems to be about the norm now. i wouldnt spend much over the $350 IMO.
i got lucky and got mine for a little over $200 shipped (seats were $180)
Old Aug 27, 2004 | 06:41 AM
ironchef25's Avatar
with the brackets.. will those seats fit an 88hf perfectly?
Old Aug 27, 2004 | 07:42 AM
yes, with the rails. and no, the 88 CRXs are different than a 90-91 (which these seats came out of i belive)
BUT, the rails and/or pans are usually a bolt on affair, so if you have 88 seats, you should be able to use those parts to make them work. no real fabrication will be needed to install though.
oh one more thing- you have very happy PASSENGERs, cause the lumbar control on those seats are for RHD Drivers, so you get screwed out of having some lumbar support a a USDM CRX Driver
Old Aug 27, 2004 | 07:53 AM
88 rex's Avatar
Those seats are EF8 seats (I have them, can't remember where i got them off the top of my head, but i'll get back to you) I paid $76 plus shipping but mine had some rips that i wasnt to concerned about.
THEY WILL FIT 88-89 without switching anything over. They did come from an EF8 which is a 90-91 BUT the bolt pattern is the same. IF you put them into a USDM 90-91 you will have to change the rails/pan (not sure about the pan, but you def need to change something). Also, if you use the rails on the EF8 seats you WILL lose leg room. So I advise (if you have an 88-89) just switching your USDM rails to those EF8 seats. Its just four easy bolts, simple. You don't have to switch, but like I said the EF8 rails dont' slide back as far b/c they came from a car with back seats.
Laskowski
Jan 23, 2007 09:53 AM
EeeJayEight
Aug 21, 2004 12:00 PM
n0 iNTegRiTY
Oct 6, 2002 04:23 PM
