Thinking about a couple small fab project.....bracket to take the trans place and cradle
Old Aug 26, 2004 | 11:10 PM
93LSivic's Avatar
Default Thinking about a couple small fab project.....bracket to take the trans place and cradle
Im about to put the car down for a couple of weeks to rebuild the trans and also do a couple of other things. I dont really have a corner of the shop to tuck it in so the car will need to be moved around when needed. I was thinking about making a brace that goes in place of the trans that will bolt to the block and then over to the trans mount.
Hopefully If I have some time I will get one made up. I was just thinking about making it from some angle iron and triangulating it for strength to hold the engine up. I will post some pics for you guys when im making it and the final product.
Also thinking about an engine cradle for the B series engines. Those V8 guys have them....we should too!! It'll make clutch jobs 10x easier when the engine/trans is out of the car, or when a swap is about to go in. Seems its always a pita to crack the trans loose fromt he engine hoist to put a clutch in w/o first putting it on the floor then proceding with the clutch swap......well you guys get the picture.
Would anyone be interested in purchasing one?? Maybe I will make a couple extra when I fab mine up.
Old Aug 27, 2004 | 12:03 AM
Evil EG's Avatar
Default Re: Thinking about a couple small fab project.....bracket to take the trans place and cradle (93LSiv
I use a 2x4 and place it from the rad support to the ledge infront of the windshield and then drill a hole in the middle of the 2x4, stick a long bolt through the hole, that has a washer welded on the end of it and I stick a bolt through the washer into where the trans mounts to the engine. So it holds the motor up while the trans is out.
Old Aug 27, 2004 | 07:06 AM
93LSivic's Avatar
Thats just too simple I want it to be a project for the new welder I just bought
Page3905
May 27, 2012 10:31 AM
okcdc2
Jan 14, 2012 11:37 PM
l2yanE
Aug 7, 2005 09:28 AM
wereami
Feb 8, 2005 02:56 PM
ScottEK
16
Sep 26, 2002 09:35 PM
