LS/VTEC Build
Old Aug 26, 2004 | 09:24 PM
shorto85's Avatar
Default LS/VTEC Build
Ok so I purchased a LS bottom bare block for $61. I plan on going for a LS/VTEC setup. Obviously I am going to be building the bottom end up first. This is mainly a project to give me something to do on my days off so I am going to be taking my time.
Right now the block is bored to 82mm. I am considering boring it to 84mm and then resleeving it to give me some more displacement and help improve my torque numbers.
Now... my main concern is the R/S ratio. As many people know the stock LS R/S ratio is very poor and not meant for revving past 7000 rpms. What do you guys recommend as far as pistons, rods, and a crank? I mainly just want to improve the R/S ratio so it will be safer for it to rev higher since this motor will be going in my daily driver.
Old Aug 26, 2004 | 09:52 PM
Combustion Contraption's Avatar
the r/s ratio isnt as big of a deal as everyone makes it out to be. Its not the be all end all when it comes to determining performance and longevity. Piston speed plays just as big a role but gets discussed much less.
With shot peened LS rods and ARP rod bolts, i think 8000rpm is safe for a daily driver. And if it is a daily driver you should get some cams that make nice power in that midrange area. ITR/CTR's are nice, maybe even some TODA A's.
Old Aug 26, 2004 | 10:05 PM
shorto85's Avatar
Default Re: (LsVtec92Hatch)
Yeah right now I am concentrating on the bottom end. After that then I will be focusing on the head. I was considering some ITR cams for it.
Old Aug 26, 2004 | 11:30 PM
b19coupe's Avatar
Default Re: LS/VTEC Build (shorto85)
If R/S ratio is a big concern for you, get a GSR crank and rods. I say stick with the LS crank and rods with ARP rod bolts.
Old Aug 27, 2004 | 06:27 PM
shorto85's Avatar
Default Re: LS/VTEC Build (b19coupe)
With the LS crank and rods will it be safe to have the redline at 8000 rpm?
Old Aug 27, 2004 | 07:33 PM
b19coupe's Avatar
I took my LS/VTEC to 9,000 fairly regularly for about a year ( with ARP rod bolts). I think 8,000 is quite safe with a properly built motor.
Old Aug 27, 2004 | 07:53 PM
topspeed86's Avatar
I have run Quite a few LS Vtecs and have ran them past 9 Grand with Jun 2 and 3's making the motor last is in the quality of the motor build.
Old Aug 28, 2004 | 09:53 AM
lsvtec240's Avatar
Default Re: LS/VTEC Build (topspeed86)
You should be fine going to at least 8500 rpm, thats what i take mine to, just get the pisons rods and crank all balanced, and arp rod bots, and you will be fine.
TheCrimsonGhost666
Aug 17, 2009 01:47 PM
MPF_supra
Apr 13, 2008 09:59 PM
Mugencrxsir1
Feb 1, 2006 10:39 PM
crxsi8
Dec 9, 2005 04:08 PM
Kingsperformance
Feb 25, 2004 02:16 PM
