timing a dohc zc??
Old Aug 26, 2004 | 07:36 PM
vmm's Avatar
vmm
Default timing a dohc zc??
whats the best timing i can do for my dohc zc?? im pretty sure its off
Old Aug 26, 2004 | 07:47 PM
Cory man's Avatar
Default Re: timing a dohc zc?? (vmm)
Why not check it first before doing any adjusting. Im assuming you are talking about ignition timing and if you are advancing it it shouldnt hurt things as long as you are on stock compression.
Old Aug 27, 2004 | 07:42 PM
vmm's Avatar
vmm
Default Re: timing a dohc zc?? (Cory man)
i dunno hpw to check, and i think its my timing, cause wen i press on gas, the revs is delayed like half a sec.
Old Aug 27, 2004 | 09:24 PM
cbrodac0424's Avatar
it is probley your timing same thing happened to me and i got it all adjusted but first i woudl try to advance trhe timing a little and see what happens good luck
Old Aug 28, 2004 | 12:49 PM
REVS-2-9K's Avatar
spinngin the distributer towrd the front of the car...does that advance or retard the timing?
Old Aug 28, 2004 | 04:21 PM
vmm's Avatar
vmm
Default Re: timing a dohc zc?? (cbrodac0424)
whats the best timing for a dohc ZC? wat shoud i advance it too?
Old Aug 28, 2004 | 06:45 PM
jlicrx's Avatar
Default Re: timing a dohc zc?? (REVS-2-9K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVS-2-9K &raquo;</TD></TR><TR><TD CLASS="quote">spinngin the distributer towrd the front of the car...does that advance or retard the timing?</TD></TR></TABLE>
turn distributor clockwise to retard, counterclockwise to advance
Old Aug 28, 2004 | 07:00 PM
ServiceAdvisor's Avatar
First, pick up a timing light or find a friend with one. Hook it up and check your current timing to see if you need to advance or retard it. Also, if you advance too much, watch your plugs to see if your leaning out. White plugs = Lean, brown and gunky = Rich. Advance to lean, Retard to richen. - Darrell
vmm
Oct 14, 2004 08:31 PM
vmm
Aug 17, 2004 06:26 PM
