to skunk 2 or not to skunk2
Old Aug 26, 2004 | 06:44 PM
Acoupdetat's Avatar
Default to skunk 2 or not to skunk2
im building my head... im planning on getting a full skunk2 head... new valves.. springs ...... retainers.....
oh with ctr itr cams.
this is all going into my gsr motor.
what do you think?
is there better for around the same price?
tuan
Old Aug 26, 2004 | 09:28 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: to skunk 2 or not to skunk2 (Acoupdetat)
i would go with them. good stuff.
Old Aug 26, 2004 | 09:31 PM
99skunkedSi's Avatar
why aren't you putting skunk cams in too? skunk's springs might be over kill for ctr or itr cams
Old Aug 26, 2004 | 10:00 PM
96redgsr's Avatar
ive heard that skunk2 valves bend easily, the stock gsr valves are good enough unless you want to go oversized, i would say just stick with the stock valves and change the valve seals once youve opened up the head.
Old Aug 27, 2004 | 01:27 AM
anothersickhatch's Avatar
Default Re: (96redgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96redgsr &raquo;</TD></TR><TR><TD CLASS="quote">ive heard that skunk2 valves bend easily, the stock gsr valves are good enough unless you want to go oversized, i would say just stick with the stock valves and change the valve seals once youve opened up the head.</TD></TR></TABLE>
i agree. stock honda valves are still bomb. the only advantages to getting skunk2 valves are compression because they are high compression valves and raise it a little. you should just upgrade the valve springs and retainers and then get your cams put in.
Old Aug 27, 2004 | 05:44 AM
-iLLuZioN-B18C1's Avatar
Default Re: (anothersickhatch)
i was gonna go with skunk2's also but now i think i may go with omnis buddy club
q8delsol
Sep 7, 2006 03:18 PM
towns
Sep 22, 2004 06:54 PM
Mefain
Feb 26, 2004 10:41 AM
speedracer9k
Oct 13, 2003 06:32 AM
P1mpSlap
Jul 3, 2003 09:17 AM
