Compression. how much?
How high of compression run on the street with no problems running on 93. what pistons should I use as well? I've heard that 11:1 is about as high as you can go on pump gas is that true or can I go higher without adjusting my timing to much.
Modified by sol_guy8569 at 7:17 PM 8/26/2004
i think will compression above 12:1 you need to take into consideration piston to valve clearance, so maybe clay your motor, also if you are gonna go above 12:1 and try to use pump gas you should probably get hondata, or something like it to tune properly so theres no predetonation problems.
down_the_hatch
37
Mar 30, 2011 07:36 PM
kantfadedisazn
21
Sep 17, 2006 11:10 PM
