Spoon vtec controller help
Old Aug 26, 2004 | 04:30 PM
shocker's Avatar
Default Spoon vtec controller help
Ok so i bought a spoon vtec controller to use for my mini that im doing to my rex.First off yes it is an odb-0 vtec controller,so it plugs right in....but i don't know which two wires on the spoon harness to splice into for vtec,could anyone help me out im kinda stuck.Much appreciation.
Old Aug 26, 2004 | 04:33 PM
shocker's Avatar
Default Re: Spoon vtec controller help (shocker)
Bump...
Old Aug 26, 2004 | 04:55 PM
shocker's Avatar
hella bumpin
Old Aug 26, 2004 | 05:07 PM
d357r0y's Avatar
I have a spoon controller on my mini me, but all the controller does is control the vtec activation point, not actually activate it.
Old Aug 26, 2004 | 06:27 PM
bryant's Avatar
Default Re: Spoon vtec controller help (d357r0y)
Sell it while you can. I had the Spoon ECU and Spoon controler and it only goes to like 6k RPM max and then down to like 1k RPM so its pretty much worthless. Just like the guy above saying all it does it move where it activates it and a little green light comes on.
Old Aug 26, 2004 | 08:21 PM
shocker's Avatar
Default Re: Spoon vtec controller help (Bryant)
Hmm so what should i do for a vtec controller? or should i go with an obd-1 conversion harness and run a p28??? But if i have to i wanna just use this vtec controller if at all possible just to give an activation point,thats all i care about
Old Aug 26, 2004 | 08:24 PM
shocker's Avatar
bump come on guys i need a lil help
Old Aug 27, 2004 | 07:28 AM
d357r0y's Avatar
You could get a VAFC and wire it up. or one of those rpm switches or convert to obd1 or get a zdyne 1 wire ecu.
Old Aug 27, 2004 | 08:49 AM
LSVTEC 91 Civic's Avatar
Banned
Might as well get a unit that controls fuel as well...
Old Aug 27, 2004 | 10:10 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shocker &raquo;</TD></TR><TR><TD CLASS="quote">Hmm so what should i do for a vtec controller? or should i go with an obd-1 conversion harness and run a p28??? But if i have to i wanna just use this vtec controller if at all possible just to give an activation point,thats all i care about</TD></TR></TABLE>
For price, you could get a VAFC. You can program it to bump up the fuel when VTEC is active. That will set you back about $300.
If you go OBD-1 then you need an ECU ($125?), distributor ($75?), 4 wire O2 sensor ($80). Right there you are near $300. You will also need to get a set of underdash plugs from an OBD-1 car ($25), hack your pre-OBD plugs off, and do the conversion wiring yourself. OR, get a conversion harness ($100) and just plug and play.
So it's up to you and the prices you can find on stuff and work you may want to do.
You could also do the VAFC and then go OBD-1 later. Then you have a little tuning and VTEC control as well.
Old Sep 1, 2004 | 10:26 AM
shocker's Avatar
Alright thanks for the help guys much appreciated.
ELIJAH EG-2
Southeast (Sales)
Oct 8, 2009 11:45 PM
spoon92hatch
Oct 17, 2003 07:49 AM
JMasta19
Dec 9, 2002 03:43 PM
HyperREV
18
Mar 14, 2002 04:51 PM
