Lowering my Idle andTPS sensor adjustment?? (k20a2)
Old Aug 26, 2004 | 04:26 PM
slowhatch4now's Avatar
Default Lowering my Idle andTPS sensor adjustment?? (k20a2)
Idle problem with my rsx type S engine(k20a2). It idles too high so the lowend power starts at 2k Rpm's( so low end power sucks anus).
Just wanted to know how i can lower the idle for my car and Where the location of the screw/ bolts are.
Also To adjust the TPS sensor on the throttle body of the type S what is needed? How is it done to adjust perfectly? Does the dealer do it? Costs?
The reason i am asking this is because i just bought a type s motor but the TPS was broken due to the accident on the front end. I replaced the sensor but have not gotten around to getting it fully adjusted, I basically put it on there and have 2 little bolts holding it in a random position.
Thanks a lot for ya help guys...
Any replies would be appreciated
Peace
Old Aug 26, 2004 | 04:37 PM
rsxmachine's Avatar
Default Re: Lowering my Idle andTPS sensor adjustment?? (slowhatch4now)
idle is not adjustable (unless you have K-Pro)
and normally the TPS is not either...
at closed throttle the TPS signal should read ~0.5 V
and fully open ~4.8 V
the idle should read 700 rpm +/- 50 rpm with the engine fully warmed up and no accessories turned on
how did you manage to replace the TPS? it's not a separate serviceable part you can buy from Acura
Old Aug 26, 2004 | 07:37 PM
Default Re: Lowering my Idle andTPS sensor adjustment?? (rsxmachine)
I Bought it off of Ebay, i dont know how they got it but i saw from the dealer that the TPS is not seperable from the TB.
About the idle, is there no way to lower it?
Im thinking that there should be someway
Peace
Old Aug 26, 2004 | 08:04 PM
rsxmachine's Avatar
nope there is no way to adjust the idle unless you have the K-Pro ecu.
actually there shouldn't be any need to adjust it as long as the IACV and throttle plate are working correctly... if it's idling too high then there's something wrong that you need to fix. you might ask Jorge from maxbore.com ("The new Spaceballs") since he works on TBs.
do you know what brand/model# of TPS it is? if it works out, there are others who need the same thing to fix damaged TBs...
Old Aug 27, 2004 | 10:44 AM
Thanks man
ill see what i can do
Peace
Old Aug 27, 2004 | 02:20 PM
rsxmachine's Avatar
good luck! with a multimeter you should be able to check the accuracy of the TPS in relation to throttle plate position
plz give me the brand/part info on the TPS you got, if it works would like to help out some others with damaged sensors
Old Aug 28, 2004 | 09:11 AM
I have no idea on part number, just typed in TPS k series on ebay and i found one
thanks
Peace
hadehatch
Dec 4, 2024 01:46 PM
gooblinn258
Dec 16, 2013 08:58 AM
5thGeneration
Jan 3, 2008 01:49 PM
b16a1civichb
Jun 4, 2003 04:24 PM
Vp Special K
Apr 4, 2003 09:14 PM
