Need help with rear disc brake conversion on my Civic.
Old Aug 26, 2004 | 03:19 PM
hexcivic's Avatar
Default Need help with rear disc brake conversion on my Civic.
Before you flame me for not searching, I searched and found several threads that gave info on break conversions.... they did jack as far as helping me out. I need answers to these questions:
I have a 96 Civic EX w/ a B18C1 swap. I have an entire 94 Integra GSR for parts.
1. Does it have everything that I need for the conversion? I already have the entire break assembly taken off and ready to go on the Civic.
2. Can I use the MC, booster, and proportional valve from the 94 GSR or do I even need them?
3. If not, what do I need and what car do I need to get the parts from?
Thanks in advance for any help you can give me.
Old Aug 26, 2004 | 04:49 PM
hexcivic's Avatar
up
Old Aug 26, 2004 | 04:54 PM
nocturnaldragon's Avatar
Default Re: (hexcivic)
Honestly i dont know but search undersomething like help with something something brake conversion Your not the first person to ask, but i know its been answered just have to search a bit more. If i knew id tell you
Old Aug 26, 2004 | 05:06 PM
hexcivic's Avatar
Default Re: Need help with rear disc brake conversion on my Civic. (hexcivic)
Okay well I searched again and if Im correct the only thing I should need is a proportional valve from a 99-00 Civic SI. Can anybody tell me if this is a fact?
Old Aug 26, 2004 | 05:22 PM
DC2EGHB's Avatar
just put the brakes on it'll work fine till you get a proportional valve. Get a proportional valve from a non ABS integra like the RS or from the eg si's. not sure if the 99-00 si's will work. otherwise every thing should bolt right up
Agguhnitus
Suspension & Brakes
Feb 15, 2012 03:07 PM
rediye
May 9, 2009 11:04 AM
Civik Sutra
Nov 3, 2005 07:52 AM
broncoman74
10
Apr 9, 2003 07:52 AM
V-SPEC 1
Jan 11, 2003 07:42 AM
