Question about Del Sol and Civic Si Throttle Cables.....
Old Aug 26, 2004 | 11:44 AM
guts311's Avatar
Default Question about Del Sol and Civic Si Throttle Cables.....
Is it true that a '99 Civic Si Throttle Cable would be the same one as a 93-95 Civic Del Sol VTEC Throttle Cable? Cause I have a frankenstein with all different engine parts in it and i need a new throttle cable... and the ex owner told me that i can either get a 99 Civic Si cable or a VTEC del sol one....is that correct that i can get either one? (cause the frayed cable i had on it was a 99 Si one according to the kid)....but Im about to order the VTEC del sol cable from honda because they dont have the 99 Si one for ordering....should i go ahead with the order? will the del sol cable be the right length?? thanks
Old Aug 26, 2004 | 12:00 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Question about Del Sol and Civic Si Throttle Cables..... (guts311)
i'm pretty sure it should fit. i'm runnin a GSR throttle cable on my del sol just fine.
Old Aug 26, 2004 | 12:02 PM
guts311's Avatar
Default Re: Question about Del Sol and Civic Si Throttle Cables..... (AzntaggeR)
cool...anyone else got input?
Old Aug 26, 2004 | 06:27 PM
guts311's Avatar
ttt
Old Sep 3, 2004 | 05:42 PM
Mrs. HybridKOOP's Avatar
what throttle body are you using and what itm? that will influence the fitting
ricanxplaya
Feb 29, 2012 04:45 AM
tr123gone
Jan 2, 2008 06:15 PM
sirt_eg
Apr 13, 2006 02:05 PM
Jerod
Jan 24, 2004 01:42 AM
