Car won't Start
Alright heres the story, whenever is hot outside and the sun has been shining on my black car, it wont start, so i took it in for a tune up and that didnt change anything, so i took it in again and they got recreated the problem with the same circumstances and what they found out is that there is no electricity going to the ignition system which means no spark on the spark plugs and the fuel pump isnt getting power either which means no fuel. It only happens when its warm outside...they said all of the coils were fine an that they cant find out so i was hoping you guys had some ideas.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa »</TD></TR><TR><TD CLASS="quote">Its probable your main relay</TD></TR></TABLE>
X2
X2
Alright so if its the main relay what would cause the relay not to work only when its hot out, the fact that parts insid of it expand when heated??? How do i tell if the relay is working properly and if it is what else could it be?
. ..... Its probable your main relay
