what the hell?now where can i get missing parts.
i got my es master bushing for 88 crx hf.. after opening it.. i find out that i cant use half of it.. what the hell... anyways do you guys know where i can get the whole rear upper and lower rear bushing kit for my 88 crx.. i cant change my lower controll arm cause i already have illuminas on them..
well. i cant remember which part they were. but its only for 89 and up.. i think its for the rear lower controll arm and something else.
i ordered it from summit.. and it said. its for 88-91 es master kit
yup.. i also checked energy suspension website. and they dont have anything for the 88 crx rear suspension bushing.
I've done this kit on my 88 si and you don't need bushings for the rear lower arms. There's no point. The shock comes with a bushing in it that is just fine and unless your rear lower arm already has no bushings in it, you will be just fine without replacing them.
Infact I wouldn't replace those bushings with poly-bushings just because the design of them, the amount of allowable "flex" in them, is incorporated with the functionality of the "passive rear steering".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 »</TD></TR><TR><TD CLASS="quote">i got my es master bushing for 88 crx hf.. after opening it.. i find out that i cant use half of it.. what the hell... anyways do you guys know where i can get the whole rear upper and lower rear bushing kit for my 88 crx.. i cant change my lower controll arm cause i already have illuminas on them.. </TD></TR></TABLE>
I have those bushings leftover from my es install. I'll send them to you for $25 shipped.
I have the bushings minus the sleeves. They're for 88 lcas. http://suspension.com/ has the the rear uca, compensator arms, and trailing arm bushings. It's about $250 for those bushings. The bushings are 3321 and 3322 (4 of each).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx »</TD></TR><TR><TD CLASS="quote">just buy some rear lca's and shocks for a 89-91 civic/crx...
i already have illuminas for the rear with the 88 lcs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic »</TD></TR><TR><TD CLASS="quote">I've done this kit on my 88 si and you don't need bushings for the rear lower arms. There's no point. The shock comes with a bushing in it that is just fine and unless your rear lower arm already has no bushings in it, you will be just fine without replacing them.
-Jon
-Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx »</TD></TR><TR><TD CLASS="quote">just buy some rear lca's and shocks for a 89-91 civic/crx...</TD></TR></TABLE>
bahhhhh...88 rear suspension owns me
kelsodeez
14
Jan 1, 2011 09:16 AM
HondaRcB
Mar 15, 2003 06:42 PM
