dx to si real quick question???
Old Aug 26, 2004 | 05:39 AM
88turdbucket's Avatar
Default dx to si real quick question???
i own a dx and im wanting to install a dohc zc, i have a spare si wiring harness and ecu. if i use that harness there is no need to do a mpfi swap because i already have the harness that i need to be made right , so there for it should be a direct bolt in right thanks for the help
Old Aug 26, 2004 | 06:17 AM
AychTwenee2's Avatar
to me ..., wiring it up without the si harness was easier. You need a resistor box as well.
Let me know if you want me to show you what to wire up.
Old Aug 26, 2004 | 07:41 AM
Jester88Si's Avatar
Default Re: (VeeTekCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx &raquo;</TD></TR><TR><TD CLASS="quote">to me ..., wiring it up without the si harness was easier. You need a resistor box as well.
Let me know if you want me to show you what to wire up.</TD></TR></TABLE>
What? Using the Si harness is NOT plug and play you'll probably have to repin the entire thing. I don't even know how you would go about this you'll still have to add wires at the chassis harness. Do yourself a favor and just use the parts you need off of the Si harness and convert it over to MPFI.
Old Aug 26, 2004 | 09:07 AM
redrumracing's Avatar
here you go check out this web site.....everything your need to do to go from dpfi to mpfi....using your dx harness
http://www.fourthgenhatch.com/mpfi.html
Old Aug 26, 2004 | 09:35 AM
Default Re: (redrumracing)
thanks for the help!!!!
knightsef-eg
20
Jan 2, 2009 01:51 PM
yz125rider21
Feb 5, 2007 12:13 PM
qcoffey
Jun 29, 2003 07:18 PM
RussHondaCRXVtec
May 12, 2003 08:16 PM
EFing8
Mar 1, 2002 05:47 PM
