aem fuel rail question
From: Long Beach/Riverside, California, United States
how do you install the aem fuel rail? its for a ls motor.... whats the fitting sizes and stuff like that... does anyone have step by step installation instructions? thanks
You just crack the fuel line feed bolt loose first to relieve the pressure. Put some paper or rags under your car since it will drain some gas out. Once that is drained take the fuel line off. Unbolt your stock fuel rail there should be like 3 nuts. Carefully pull the rail off the fuel injectors. Get some new orings for the tops of the fuel injectors then take your AEM rail and put it on the inejectors, bolt it down, put on the fuel line and call it day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs »</TD></TR><TR><TD CLASS="quote">What about the harness that bolts down to the the stock fuel rail? Did you just zip tie it? Thanks!</TD></TR></TABLE>yah you could probably do that.
drift2004
Mar 29, 2005 09:56 PM
TypeRuz
Nov 19, 2003 11:40 AM
