gauge cluster lights not working
i did a teg dash swap and the lights do not work on the gauge cluster, did many searches never really heard of anyone having this problem maybe bad dimmer switch, i doubt its a fuse i hceked, anyone know which wire is the power to the lights on the dash i know theres 3 power wires. if one bulb is blown the rest should work right? any ideas. TIA
i had same problem.. it was my dimmer switch.. also none of the lit up stuff would work like climate control console shifter lights...
i swapped it with anoter and it worked
swtch7
Sep 4, 2008 04:22 AM
philkehn
Nov 5, 2006 08:39 PM
