gsr cluster? pics?
Old Aug 25, 2004 | 09:30 PM
Karate Chop's Avatar
Default gsr cluster? pics?
can someone explain to me the idea of putting a 94+ gsr cluster into ef civic/crx's, does it go right in or something cause it seems pretty popular to do, does anyone have any pictures of it in the car and working properly?
Old Aug 25, 2004 | 09:34 PM
em Dot's Avatar
POOPCheeks
Default Re: gsr cluster? pics? (jdmsir1)
i heard of people putting the whole gsr dash in place so that the gauge cluster would fit right. the problem is that the crx bezels are square-ish and the gsr are rounded.
Old Aug 26, 2004 | 05:13 AM
schwanginpt's Avatar
I have a USDM LS cluster in my CRX - same look as the GSR, but wiring is totally different. Im making a custom craddle for the cluster to bolt to, and reworking the gauge surround.
heres a pic of mine - if you notice on the sides of the cluster- the OEM Honda surround cuts off the sides of the gauges slightly, Im modifiying mine to fit properly
Old Aug 26, 2004 | 07:47 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: (schwanginpt)
Man that **** looks good. I had a gsr cluster but i never put it in because i have an LS and id never be able to reach the redline on the tach...yes i know its not that big of a deal but im picky. So id love to get ahold of an LS on. How difficult was the wiring? Thanks
Old Aug 26, 2004 | 08:24 AM
thats the same reason i used an LS cluster. closest to a D16 redline.
wiring was umm.. difficult. for some reason GSR and LS wiring is almost ALL different. I had a beat gsr cluster and after wired for the LS cluster, only thing that worked were a couple of the light indicators.
I just traced the back of the cluster to the pin, and then used one of the sites that list what the PIN location of a CRX is, and compared them and repinned.
Old Aug 26, 2004 | 09:00 AM
holy ****, that doesnt sound easy or fun, you people are crazy, what about wiring for a gsr cluster as opposed to the ls, cause i WILL be able to reeach that redline
Old Aug 26, 2004 | 11:40 AM
daidilus's Avatar
Default Re: (jdmsir1)
you may have had clusters from different generations......the 94-95 have the same pin-outs, and the 96 plus have another set of them....if you have the manuals to all the cars , you can write down the colors, cut and solder.....that is what i did..
if you know how to read...all the information is there
Modified by daidilus at 4:46 PM 8/26/2004
Old Aug 26, 2004 | 12:05 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schwanginpt &raquo;</TD></TR><TR><TD CLASS="quote">
and then used one of the sites that list what the PIN location of a CRX is, and compared them and repinned.</TD></TR></TABLE>
What Site?
Old Aug 26, 2004 | 12:32 PM
i did a search here on H-T, and there was a thread with a bunch of links. i dont have them bookmarked on this computer
Old Aug 26, 2004 | 12:41 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
it took me a long time to put my gsr cluster in. none of the wire diagrams online are fully correct so i had some left over wires. anyway i liek the new cluster and i get alot of compliments.
Old Aug 26, 2004 | 01:01 PM
CRX T-Si's Avatar
Default Re: (91siredrex)
Is there a write-up on how to put the OBD-1 Teg cluster into the EF???
That **** looks awesome.
schwanginpt did you get that steering wheel new, cause damn your car looks like it was kept in the showroom condition.
Old Aug 26, 2004 | 01:18 PM
daidilus's Avatar
Default Re: (CRX T-Si)
http://crxpower.net/phpBB2/viewtopic.php?t=5383
Old Aug 26, 2004 | 01:36 PM
ScottEK's Avatar
Just a note for anyone who is going to attempt this, MANY of the tutorial sites online that are linked to from this site are horribly wrong on the pinouts. It takes combined information from multiple sites to get everything working properly but it can be done. I love mine, it makes the car feel 10 years newer!
Old Aug 26, 2004 | 01:47 PM
daidilus's Avatar
yeah i know...that is why i still like my car...
Old Aug 26, 2004 | 02:02 PM
ICeDoUt's Avatar
Default Re: (daidilus)
yea def all sites i found for doing the gauge cluster conversion are off, i had to get schematics for both my crx, and a gsr. lots of time and yelling and screaming, don't forget breakin stuff
Old Aug 26, 2004 | 02:08 PM
daidilus's Avatar
meh...if you just sit down with the print outs from both cars, write out the colors, and wires so when you get to cutting and soldering...you will know exactly what to do.
Old Aug 26, 2004 | 02:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Is there a write-up on how to put the OBD-1 Teg cluster into the EF???
schwanginpt did you get that steering wheel new, cause damn your car looks like it was kept in the showroom condition. </TD></TR></TABLE>
just about. I got it from Austrailia, and i dont think it was ever used on a car. the center horn button wasnt even installed when i got it. and when i work on the car or around the wheel, im careful not to get it dirty.
it cost me a pretty penny too
Old Aug 26, 2004 | 02:51 PM
XJamesX's Avatar
Just go with the 99-00 civic si cluster. I think it looks better. Here is my how to. The pin outs for the crx are correct if you want to use them. Just my help.
https://honda-tech.com/zerothread?id=709958
-James-
Old Aug 26, 2004 | 04:35 PM
d16X's Avatar
those all look good
vndsd1
Northern California (Sales)
Apr 14, 2010 10:50 PM
FSTVTEC
Sep 13, 2009 04:19 PM
japrex
Nov 21, 2004 07:22 PM
