Ls/Vtec Exhaust Questions
I was wondering what you guys think of this exhaust set up I plan to run when my motor is finally done.
Motor:
b18b block, Type R Head, Skunk2 Stage 2 cams, Skunk2 full valvetrain, Endyne Rollerwave pistons, 12.5:1, 81.5 bore. Alot more parts, but these are the basics, check sig for more info and pics.
Exhaust:
An-R Standard version header with 2.5 merge collector
2.5 flex pipe
2.5 Carsound cat
apexi n-1, turbo aspirated cat back(already had on car before build)
The cat back is 2.5 inch with a 3 inch tip. I do not want to run open header.
Pls give me your thoughts on this exhaust set up, before i go out and buy. I have done plenty of research, and would just like to see what other ALL-Motor people think about this set up.
Motor:
Exhaust:
2.5 flex pipe
2.5 Carsound cat
Set up looks good but I'm not an "R" header fan...get it dynoed once its done and that's the best advice you'll get...Numbers don't lie.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">...I'm not an "R" header fan...</TD></TR></TABLE>
as in An-R?? What do you not like about the header, besides the thin piping?? havent really been able to find #'s on an An-R.
Nothing drastic...except on header poll, it came up short in hp numbers. There was a thread a few months back on headers...you might want to search...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 »</TD></TR><TR><TD CLASS="quote">...we can custom design one direct to your application</TD></TR></TABLE>
check the sig for the motor specs, and get back to me with a price, looking to order a header next week, also, any #'s you can give me about your header would be great. thanks for the response.
Also how is the ground clearence, i was looking at the An-R because of the ground clearence.
