swapping b18a1 into a 1989 honda crx si
Old Aug 25, 2004 | 07:10 PM
bugsy's Avatar
Default swapping b18a1 into a 1989 honda crx si
pretty much im tryna swap a b18a1 out of a 91 acura integra can somebody please tell me what is needed im pulling the motor along with anything else that might be needed he said something about the timing belt what should i look for could it be rebuild or what somebody please give me some feed back
Old Aug 25, 2004 | 07:12 PM
SiRex91's Avatar
Default Re: swapping b18a1 into a 1989 honda crx si (bugsy)
Replace the water pump and timing belt. Also, it would be a good time to upgrade the clutch and flywheel.
Old Aug 25, 2004 | 07:20 PM
sit220's Avatar
all im going to tell u is to do some search
take everything u can out the integra ecu motor trany rear disk brakes
o u need to buy motor mounts
for more info search
Old Aug 25, 2004 | 07:55 PM
Reason's Avatar
you pretty much have everything that you need besides shift linkage and motor mounts. this is the easiest swap that you will probably ever do. i did it in my 89 CRX Si. the only difference was, i had a 93 b18a1. but just change the waterpump and tb while you have the motor out. and use the integra axles, and the integra ECU, and your Si engine harness, and you should be good.
Old Aug 25, 2004 | 07:57 PM
tRex99's Avatar
I have it in my 91 si took me a day to get everything pretty much done. You take motor, tranny, ecu, take the clutch cable and throttle cable it makes everything so much easier too. Everything is plug and play use ur crx si harness off your old motor. Your check engine light will come on but thats because the crx didnt come with a crank angle sensor i think it was in the rear so take it to your local import shop and have them wire that up it only take like 15 mins if they jump right to it and they charged me like 50 bucks...You got your mounts and shift linkage i hope...What they are saying is good too though change that timing belt now and water pump its a ping while the motors in...Oh yea dont forget to beat ur frame in where the alteraantor goes just make a good dent in it or the pulley will either come too close or rub. U'll love it its quick im eatin gt mustangs up all day...pretty much anything that comes factory thats not exotic or a higher model car thats pretty expensive will get eatin up by you...good luck i think i covered it all....
sleepercrxk24
Sep 14, 2010 09:02 PM
joesbadcrx
May 19, 2006 11:05 AM
newBcrxer
Sep 9, 2004 01:43 PM
dreadhead
Jul 27, 2004 02:24 PM
mixmasterkeg
Mar 3, 2004 09:59 AM
