smoke comming from where i put my oil??
Old Aug 25, 2004 | 06:00 PM
itsJDMyo's Avatar
Default smoke comming from where i put my oil??
ok, earlier today, i was driving home, and then started to smelling this really bad burning smell from my engine...so when i got to my friends house, and checked my oil, i was 1 quart less...so i decided to add more oil in, so when i opened the oil cap, there was smoke comming from inside the head...this has never happend to me before, it was pretty cold today. even on hot days, when i open my oil cap, smoke doesn't come out...so i added oil and drove it...i didn't smell it anymore, but when i popped my hood again and opened the oil cap, smoke started comming out again...is this normal??
Old Aug 25, 2004 | 06:14 PM
Deemeetree's Avatar
Electrician
Well most of the time, when my engine is up at normal operating temperature, this happens also. Not a lot of smoke, just a little bit. It's fine. Just hot oil circulating and not really going anywhere.
Old Aug 25, 2004 | 06:15 PM
blykins's Avatar
Banned
Default Re: (Dimi)
I get a little smoke out of my oil cap. I also get a lil smoke when pulling out my dipstick. Hot oil is going to smoke, especially when its cooler outside.
Old Aug 25, 2004 | 06:45 PM
Deemeetree's Avatar
Electrician
Or when you're doing 75mph on a 100* afternoon for 140 miles.
Old Aug 25, 2004 | 07:54 PM
Street Ghost's Avatar
Default Re: smoke comming from where i put my oil?? (itsJDMyo)
That happens to me sometimes too.. but no bad burning smell from the engine tho.
Old Aug 25, 2004 | 08:31 PM
95sihb's Avatar
Default Re: smoke comming from where i put my oil?? (JDM Ninja)
It's Normal
Old Aug 25, 2004 | 08:58 PM
Quik Chris's Avatar
Default Re: smoke comming from where i put my oil?? (95sihb)
If it's excessive, it could be a bad PCV valve-- pull it out and shake it. If it clicks, it's still good and working, if it doesn't, it needs to be replaced. This could also be bad rings/cracked ring lands-- in this case, you're getting blow by and it's coming out there.
Old Aug 25, 2004 | 09:07 PM
murmur9's Avatar
Default Re: smoke comming from where i put my oil?? (Quik Chris)
i dont know about the smell, but this has always happened with me after i have driven the car for a while. on both of my engines
Old Aug 25, 2004 | 10:18 PM
itsJDMyo's Avatar
Default Re: smoke comming from where i put my oil?? (murmur9)
the smell is like a really strong burnt rubber scent...it freakin stinks...and it just started smelling like that today
Old Aug 25, 2004 | 11:17 PM
GdmLaz's Avatar
Its normal for when you been driving your car and u open the cap for smoke to come out is kinda like common sence OIL REALLY HOT when u open and iis colder outside which is going to be a lil smoke is going to come out
Old Aug 26, 2004 | 12:16 PM
itsJDMyo's Avatar
Default Re: (Slammed92hbonN20)
does that really strong burning rubber smell has anything to do with it though? cuz it was a strong scent, but i'm afraid it might be something else burning
thisoneroller
Honda Civic (2006 - 2015)
Feb 22, 2011 07:15 AM
Terrance
20
Jan 6, 2006 10:42 PM
chickenandpickles
16
Sep 11, 2005 01:29 PM
redlude97
Jun 24, 2005 06:01 PM
KiNG $h!t
Jan 28, 2005 08:50 AM
