Is My T3 Turbo blowing out my SPARK from the spark plugs??
I think my turbo is blowing out my spark, I have a much upgraded Fuel System.
When the Car is at normal temperature, And start to get into boost mode,4-5000 RPM. my car seems to "misfire", it will make like a TATATTAT sound. Like a machine gun. I am using OEM NGK plugs with an unmodified Plug Gap. MSD 6A box along with a Blaster 2 coil.
Any Info or Suggestions????
Thanks.
-Vote Kerry
Thanks.
-Vote Kerry
hey whats up d16turbo. i can help u on this get ngk bkre7. they are one step colder and gap them to 0.30 and your spark wont blow out
Oh ****, I thought that name looked familiar. Thanks for the info, right now I am reading : https://honda-tech.com/zerothread?id=510127
but what version is it. this pic came up at advance auto parts under BKR7E AKA NGK-6097.
This pic: http://www.partsamerica.com/pr...s.jpg
HA.
Are you being sarcastic or are you representing the sound of detonation
Hey, ah, honda9369 are BKR7E-11 The V-Spark or Standard. I head V-Spark Is an over kill for turbos?
I've been experiencing the sme problem for some reason just recently. Get into boost and the car seems to lose power and seems to misfire. I threw a P1123 code (short-term fuel correction too low) and went to like 10:1 AFR.
I will try going to a colder plug, but with only 50% more power than stock I don't think I need it?
Well since you say get the VPOWER, which is BKR7E-11... Those come as .44 gap. SO the question is are the VPOWER gaps adjustable just like the normal ones. im trying go get a .38 gap or so.
Well, I rechecked the plugs, spark plug wire continuity, and my wiring for the S-AFCII and the MSD DIS-2, and it didn't fix it. Turns out, I simply miscalculated the low-throttle fuel correction with the AFC. My stock injectors are 15# and I am using 19#, so I figured I would need (15/19-1)*100 or -21% correction.
But this didn't work, and my ECU (an OBDII) was maxing out the short-term fuel correction to try to make the engine run stoich. This is what caused the trouble code and the misfiring.
After a couple test runs I found that -10% across the low-throttle correction worked fine. I am still using -15% for the high-thottle, though. (With the OBDII I am unable to really tune the low-throttle, but it doesn't matter since boost comes at high throttle anyway, and the ECU can correct for several pounds of boost when cruising. I don't know why so many Honda guys switch to OBDI)
The car runs like a champ again.
