Help w/ code 17: VSS
Old Aug 25, 2004 | 12:06 PM
Propulsion's Avatar
Default Help w/ code 17: VSS
I have been trying to figure this out for a while to no avail.
this is a 89 civic dx w/ a b17, running on obd0 pr3 ecu
tried swapping clusters, tried wiggling the sensor in the tranny, checked the ecu pin, everything looks right, but when I drive the car for a couple minutes, the lights comes back on.
What should I try next?
Old Aug 25, 2004 | 12:47 PM
boosh's Avatar
Default Re: Help w/ code 17: VSS (SilverCIVIC96)
is you rlittle retainer clip thingy around the cable? after doing my tranny swap, my speedo didnt work either. turns out i had dropped the little clip... a papper clip works pretty well as a substitute
Old Aug 25, 2004 | 03:00 PM
Propulsion's Avatar
Default Re: Help w/ code 17: VSS (boosh)
my speedo works fine, and the clip is there
Old Aug 25, 2004 | 03:20 PM
crexer's Avatar
have you tried unhooking your battery for a few minutes to re-set your ecu?
Old Aug 25, 2004 | 04:32 PM
Propulsion's Avatar
Default Re: Help w/ code 17: VSS (crexer)
yep, tried that quite a few times.
Old Aug 25, 2004 | 05:26 PM
crexer's Avatar
what light are you talking about?? Im guessing its not electronic VSS so take your cluster out and when driving look at where the cable hooks into the back of your speedometer and see if that black pin is constatly spinning when the vehicle is in motion. If it is not turning then u know the problem is not the cluster it might be a bad cable...
Old Aug 25, 2004 | 06:22 PM
B16 CRX's Avatar
I had the same problem after doing the motor swapp, it turns out that I had to take out my gauge cluster and wiggle the Vss from the back of the cluster a couple of times, now it works fine. Hope that helped
Old Aug 25, 2004 | 07:24 PM
Propulsion's Avatar
Default Re: (WhiteCRXSi)
yeah that thing rotates when Im driving. So that rules out the actual gear/cable assembly.
Switched the cluster and still throws code, so that rules out the cluster.
I tested the wire from back of the cluster (yellow/red) to the computer (pin B16) and it has continuity.
Im stumped
WhiteCRXSi, did you wiggle it while attached to the cluster?
Old Aug 25, 2004 | 07:58 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (SilverCIVIC96)
mabey your ecu is screwed?
Old Aug 25, 2004 | 11:02 PM
Propulsion's Avatar
Default Re: (JC18)
yeah that might be the problem. I need to find another pr3/pw0 to test
SiR_Injected
Oct 21, 2007 07:24 AM
jonathancrx
Jul 17, 2005 05:17 AM
Joebroni
May 29, 2005 12:43 PM
C-RICKS
Jun 23, 2003 03:08 PM
^Sammy]!.
Apr 6, 2003 05:19 PM
