Where is the location of the service connector for 1994 2.2 prelude import?
I have looked by the passenger footwell, driver fiotwell, behind stereo for the service connector for my 94 2.2 prelude. this is a import car so the steering wheel is on the left side of the car (if looking at it from outside)..
can anyone tell me where it is? also what are the colours of the 2 wires connecting into it? i know the connector is blue..
thanks in advance.
thanks in advance.
in mine (as with other 4th gen preludes) the service connector is right underneath the stereo. You pretty much have to get on your back and look. there are 2 plugs on the floor one gray one blue, both plugged in to a clip. unplug the blue one, that's the service connector.
It's behind the center console, try looking for it from the driver's side (left). Easiest way is to remove the radio and follow the wiring in the back. Most of the time, it's plugged into a soft plastic piece. The blue connector with two wires coming out is the service connector.
I could see mine with the ashtray removed, i just reached behind the console and fished it out.
When i was done i left it out and just tucked it slightly behind the console. Now if i need to check codes i can do it in less then 30 seconds.
thanks guys I found it and got the following blinks..
3 short
1 long
7 short
2 long
1 short
Does that mean a code 41? if so what does that mean and what can be done to sort it out?
thanks
3 short
1 long
7 short
2 long
1 short
thanks
NJ VTECpowered
Mar 8, 2007 07:44 AM
