Best ECU for ZC
Old Dec 4, 2001 | 05:11 AM
Hondasaurs's Avatar
Default Best ECU for ZC
Whats the best ECU to use in the ZC DOHC engine? What about the 94 integra ECU? Will that work?
Old Dec 4, 2001 | 05:22 AM
markedOO1's Avatar
Default Re: Best ECU for ZC (ZC_CRX)
no, the 94 teg ecu is an OBD1 ecu, you need and OBD0. the best ecu's for the zc are the zc ecu (obviously) which is the pm7 or the 88-89 teg ecu (pg7)
Old Dec 4, 2001 | 05:42 AM
Mugen Dom's Avatar
Default Re: Best ECU for ZC (marked001)
yeh teh teg will mke it run rich the zc ecu is best for emision purposes
marked how did everything go with the problem i fixed my idle and found a door panel for my driverside and got some dsm injecters for future project just wanted to check up on the news
Old Dec 4, 2001 | 05:44 AM
markedOO1's Avatar
Default Re: Best ECU for ZC (jdmB18hatch)
...still no go now I have no spark all of the sudden. I'll get it fixed one of these days
Old Dec 4, 2001 | 05:58 AM
Mugen Dom's Avatar
no spark thought it was there before wasnt it check all the connections its always so obvious it could say here i am and u still wouldnt see it
Old Dec 4, 2001 | 06:05 AM
markedOO1's Avatar
yeah, I know its something stupid
Old Dec 4, 2001 | 06:08 AM
Mugen Dom's Avatar
yeh, remeber that kid from north jersey 91crxsi got that sohc zc inhis car im goin up tocheck itout today he said it runs strong
Old Dec 4, 2001 | 06:13 AM
REDBARON's Avatar
Hey If you're looking for a 88-89 integ ecu (PG7), I have one. Just let me know.
Old Dec 4, 2001 | 08:59 AM
McD's Avatar
McD
Default Re: Best ECU for ZC (VTECHatch)
I have a 89' teg ecu and I totally satisfied, but if I could get my hands on a ZC ecu I would definatly pick that up
Old Dec 4, 2001 | 09:18 AM
Phatwhippin_CRX's Avatar
Default Re: Best ECU for ZC (amethistco)
The problem with the Teg ECU is that is makes the ZC run rich, and fry distributors. Notice how all the ZC people with distributor problems are running 89 Integra ECU's....... coincidence? I think not.......
Old Dec 4, 2001 | 09:24 AM
McD's Avatar
McD
Default Re: Best ECU for ZC (Phatwhippin_CRX)
Yeah true.. If I am sitting some where with my car idling I can smell the gas big time.
Old Dec 4, 2001 | 09:49 AM
REDBARON's Avatar
Well that's not entirely true. The ecu works great with this engine and my brother never had a problem with it being too rich. But then again he did have a FPR, and it was dynoed also.
Remember, don't just think that slaping a mod on will work in harmony with whatever else you have on the car.
The key to making power is tuning!!
Old Dec 4, 2001 | 09:52 AM
EP3_05's Avatar
The adjustable FPR will help make the teg ecu work better with the zc. The teg ecu without fuel adjustment runs hella rich with the zc. So it might be to your benefit to get a teg ecu and an fpr because the zc ecu can be tough to find sometimes.
Old Dec 4, 2001 | 09:59 AM
McD's Avatar
McD
Default Re: Best ECU for ZC (91civic)
I think I'll get a FPR for my car... What Psi should I run with my teg Ecu?
Old Dec 4, 2001 | 10:12 AM
REDBARON's Avatar
You have to get it dynoed. It all depends on what other mods you have. Also not every engine will run the same at a certain psi. You can also get a a/f meter and try and do it yourself, but getting it dynoed is going to be the best way to make the car run smooth.
Old Dec 4, 2001 | 10:15 AM
McD's Avatar
McD
All right, I think I'll do that. Thanks
Old Dec 4, 2001 | 01:55 PM
Hondasaurs's Avatar
yea im interested in it. I cant find any 89 intrgras in junk yards here. email me at hellspawnonline@hotmail.com
Old Dec 4, 2001 | 01:56 PM
Hondasaurs's Avatar
Old Dec 4, 2001 | 02:16 PM
ZygSpeed's Avatar
What's different between the 87 teg and the 88-89 teg ECUs?
The reason I'm asking is because I'm about to buy a used Zdyne unit for a 1st gen CRX Si/87 RS teg (Drag II) hybrid, and I was wondering about the injector type (saturated vs. peak-n-hold) and any possible distributor incompatibilities. TIA
P.S. the Zdyne is actually supposed to be for a 88-91 Si.
[Modified by zygspeed, 6:17 PM 12/4/2001]
Old Dec 4, 2001 | 02:18 PM
EP3_05's Avatar
Default Re: Best ECU for ZC (DOHC DX)
nono, my personal experiences prove otherwise. i have a Zdyne ZC conversion ecu and that damn thing straight ***** my zc up, the distributor goes haywire, the rpms will jump constantly and i've replaced my ignitor three times already while using that ecu. went to the junkyard picked up an 89 integra ecu, plugged it in, and my zc SMILED lemme tell ya. NO MORE problems whatsoever. runs strong from idle to 7500. so either the zc program sucks ***, or zdyne does...and personally i think it's the latter...
Hmmm.... I have the zdyne and it is perfectly fine in my car. I haven't fried a thing and my idle is quite steady. Maybe you just got a bad program. Who knows....
Old Dec 4, 2001 | 04:13 PM
bryant's Avatar
mmm...www.zdyne.com
Old Dec 5, 2001 | 07:33 AM
REDBARON's Avatar
Default Re: Best ECU for ZC (CR-X)
Hey ZC_REX, you've got mail.
Old Dec 7, 2001 | 07:09 PM
Denny317's Avatar
ZC ecu
Old Dec 8, 2001 | 12:37 PM
Magick211's Avatar
Default Re: Best ECU for ZC (Turbo Denny)
Hmmmm. Im not sure wich ecu to get for my zc. I guess im gonna stay on the lookout for a zc ecu
deerek101
Feb 7, 2006 05:10 PM
Cambo88zc
Jan 21, 2006 05:07 PM
ivanson
Mar 19, 2005 08:16 PM
1990civicsiguye
Jul 30, 2003 06:21 PM
-=TWITCH=-
Jan 14, 2002 07:55 AM
