B16 SWAP- TOP END QUESTION
Old Aug 25, 2004 | 04:49 AM
slimcivic95's Avatar
Default B16 SWAP- TOP END QUESTION
i have a stock b16 swap with i/h/e and pulley and msd. I want to put skunk2 dual titanium valve springs and retainers w/ either ctr or itr cams. Which would you guys recommend. Also what would the motor redline at with that setup. THANKS
Old Aug 25, 2004 | 05:42 AM
91civicDXdude's Avatar
IMO, you would be a lot better off and happier with a larger aftermarket cam. For the same price as CTR or ITR cams, you can get a nice beefy set with higher lift & longer duration for more power.
Old Aug 25, 2004 | 12:42 PM
chad174's Avatar
Default Re: (91civicDXdude)
the CTR cams are a nice upgrade to a modded b16. Also consider the skunk stage 1's.
Old Aug 25, 2004 | 01:56 PM
eglover92's Avatar
keep it oem...honda is not dumb...theyve spent **** loads of money on research and development that u dont need aftermarket parts...OEM OEM!!!
sick93sol
110
Sep 7, 2009 09:07 PM
caranjo
Feb 24, 2005 09:19 AM
Damon
Feb 18, 2004 12:44 PM
markie
Aug 27, 2003 06:19 AM
VTECHEART
Mar 22, 2002 09:05 AM
