Need to know ASAP, will a 96-00 ek swaybar work on my 92 cx ???
Old Aug 24, 2004 | 10:53 PM
Tad's Avatar
Tad
Default Need to know ASAP, will a 96-00 ek swaybar work on my 92 cx ???
Was about to buy a swaybar,
but I noticed it was for 96-00 civics,
I know those come with lcas that can accept swaybars,
but is there any other difference that would make it not work on an eg chassis?
my car is a 92 cx.
i plan on swapping out the lcas or drilling the hole
need to know asap!!
thanks!
Old Aug 24, 2004 | 11:56 PM
Gump's Avatar
Default Re: Need to know ASAP, will a 96-00 ek swaybar work on my 92 cx ??? (Tad)
Should fit. I had A GSR swaybar on my 00 Si once, so if you think about it, they're pretty much interchangeable, now the only problem I can think of, is the endlinks.
Old Aug 25, 2004 | 07:11 AM
Tad's Avatar
Tad
yeah its the subframes I think,
EG subframes are alil different from EK subframes.
hmm, now that I think aobut it, i just parked right next to an EK.. haha I should go look.
I'm going to see if I can swap the brackets out or something.
Old Aug 25, 2004 | 08:06 AM
murmur9's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">
I'm going to see if I can swap the brackets out or something.</TD></TR></TABLE>
hahaha so, what did you find out? I would like to know for future ref.
Old Aug 25, 2004 | 10:07 AM
Tad's Avatar
Tad
Default Re: (murmur9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 &raquo;</TD></TR><TR><TD CLASS="quote">
hahaha so, what did you find out? I would like to know for future ref. </TD></TR></TABLE>
yeah the ek subframe and lcas are shaped differently than the eg ones.
they're beefier.
the lcas are alot thicker(top to bottom),
and the eg subframe kindof comes to a point where it attaches to the lca,
whereas the ek subframe just stops flat.
the holes on the subframe are alittle different too
Old Aug 25, 2004 | 10:11 AM
Guest
Posts: n/a
Yeah the "EG" LCAs are really thin they look pretty weak; but I do believe you can use the "EK" sway bar; if not shell out 50 bucks and just get an ITR one?
Old Aug 25, 2004 | 10:57 AM
blykins's Avatar
Banned
Default Re: (Vinnie Paz)
Why not just use EK LCA's if its the EG LCAs are the problem.
Old Aug 25, 2004 | 01:12 PM
Tad's Avatar
Tad
lcas aren't the problem the subframe is.
its shaped differently, requiring a different swaybar mounting bracket.
I had to pass on the swaybar
EF'n Sedan
Mar 18, 2009 06:16 PM
wackarnolds
Jul 25, 2006 09:43 AM
lerner
11
Apr 18, 2006 05:35 PM
tongman
42
Mar 9, 2005 06:37 AM
Frozen E
Aug 15, 2004 06:22 PM
