Difference between 97-98 and 99 -01 R's
Old Aug 24, 2004 | 10:47 PM
PDM's Avatar
PDM
Default Difference between 97-98 and 99 -01 R's
Im recently in the market for a Type R.
My question is what are the differences between the 2 gens of type r's besides the obvious integra front end design change and immobilizer. Any advantages or disadvantages?
Old Aug 24, 2004 | 10:49 PM
Haleiwa-Brando's Avatar
Default Re: Difference between 97-98 and 99 -01 R's (PDM)
Just a heads up, people here are going to tell you to do a search.
Bbasso's Avatar
try ITRCA for info on this question you have.
Old Aug 24, 2004 | 10:52 PM
p nut's Avatar
Price
Old Aug 24, 2004 | 10:55 PM
esponet's Avatar
as far as performance, nothing. its pure preference. if you live in u.s. and you want a cw then you have to buy 97-98. or re-paint it. same goes for yellow or black 00-01.
Old Aug 24, 2004 | 11:04 PM
PDM's Avatar
PDM
Default Re: (esponet)
Thanks. found a lot of info on the ITRCA site but since i live in Canada a lot of the info doesnt apply to me. Just interested to see if they made any changes other than cosmetics but ive seemed to have found most of the answers I was looking for.
Old Aug 24, 2004 | 11:09 PM
Default Re: (PDM)
PDM...this little bit of information may be of use toward you since your up North.
http://www.j-garage.com/1210.htm
Old Aug 24, 2004 | 11:29 PM
ITR 2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">as far as performance, nothing. its pure preference. if you live in u.s. and you want a cw then you have to buy 97-98. or re-paint it. same goes for yellow or black 00-01. </TD></TR></TABLE>
I'm about 79.786543% sure that the 00-01 uses different cams.
Old Aug 24, 2004 | 11:37 PM
EuN_TeK's Avatar
Default Re: (ITR 2K)
I thought performance wise there were differences... The older models always seem to make less power on the dyno in their stock form than the newer models. And yes, I'm pretty sure the cams are different as well.
Old Aug 24, 2004 | 11:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 2K &raquo;</TD></TR><TR><TD CLASS="quote">
I'm about 79.786543% sure that the 00-01 uses different cams.</TD></TR></TABLE>
I cannot remember which one but ONLY one of the cams is different. I think it's the exhast cam on the 00-01. I am 50% sure.
4-1-1's Avatar
Canada ITR's:
97 (kinda differnt front/rear) CW
98 CW
99 (there is a ITR model in 99 for Canada) CW
00 PY (CW maybe i forgot)
01 CW (w/ the red interior)
Isn't it just the Intake cam lobe?
Old Aug 25, 2004 | 04:12 AM
b19coupe's Avatar
Default Re: (4-1-1)
The 00-01 intake cams have 3 degrees more duration than the 97-98.
Old Aug 25, 2004 | 09:25 AM
white rocket's Avatar
Default Re: (4-1-1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-1-1 &raquo;</TD></TR><TR><TD CLASS="quote">Canada ITR's:
98 CW
01 CW (w/ the red interior)</TD></TR></TABLE>
According to Acura only PY was offered in 2000 in Canada. I know 'cause I tried to get one every year since 1997. F**kin' dealer mark-ups!! And, yes, there is a CW 1999 model because I own one. I think the 1999 is the same as the 1998 and the 2000 offered a/c, immob. and maybe other stuff, I'm not sure.
Old Aug 25, 2004 | 11:15 AM
PDM's Avatar
PDM
Default Re:
Like someone mentioned earlier, do the newer Type R's dyno higher than the older models? from what ive read the intake camshaft is different. This is the kind of info i've been wanting to know.
Old Aug 25, 2004 | 12:00 PM
B18C5's Avatar
Default Re: Re: (PDM)
The HP difference between different years is smaller than the HP difference between different cars. In other words you're just as likely to get a stock 97 that dynos higher than an 01 as you are to get an 00 that dynos higher than a 99.
AFAIK the intake cam change was to compensate for a loss of power due to emissions changes.
Old Aug 25, 2004 | 12:04 PM
PDM's Avatar
PDM
Default Re: Re: (B18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5 &raquo;</TD></TR><TR><TD CLASS="quote">The HP difference between different years is smaller than the HP difference between different cars. In other words you're just as likely to get a stock 97 that dynos higher than an 01 as you are to get an 00 that dynos higher than a 99.
AFAIK the intake cam change was to compensate for a loss of power due to emissions changes.</TD></TR></TABLE>
exactly the answer I was looking for. Thanks
Old Aug 25, 2004 | 12:17 PM
RagingAngel's Avatar
I've witnessed here in Vancouver a couple of 01s dyno very close to 170whp if not slightly over 170.
Mine already dynoed strong at 167 back in the day.
I believe the cams helped but I also suspect the ecu may be "smarter" stock. It's the small case ECU compared to the prev. years big case. Not sure if that has much to do with it....but many a 01 I have driven has felt great....
that or I was hypnotized by the new car smell....
Old Aug 25, 2004 | 12:23 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
1 degree of duration ( not much of a difference on stock compression ) compared to CTR. 3 degrees difference in the 97-98 vs 00-01
but im only 79.786544% sure of this
Modified by Nvious R at 4:24 PM 8/25/2004
Old Aug 25, 2004 | 02:10 PM
DsITR's Avatar
97's have..
different front bumper/lip
different rear bumper lip
no rear wiper
no AC unless installed by dealer
no carbon fiber pieces on the dash
97+98 only came in Championship White
there are no 99's in the US AFAIK
00-01 came in Phoenix yellow
00 and 01 had only the black ie (NBP or FBP) but I forget which year is which.
...sure there is plenty I'm forgetting.
As far as advantages the 97's tend to carry higher resale value, due to their rarity. performance wise the 00-01's have the different cams other than that they are pretty similar.
Old Aug 25, 2004 | 02:24 PM
Nvious R's Avatar
Default Re: Difference between 97-98 and 99 -01 R's (DsR)
isnt the steering gear ratio different between the 2 gen's of R's? I believe the 00-01's have quicker steering.
Old Aug 25, 2004 | 04:54 PM
Utilitarian's Avatar
LOAN VALUE!
floormats people, floormats!
I think the 97-98's only came in white.
Old Aug 25, 2004 | 11:21 PM
Charlie R's Avatar
Default Re: Difference between 97-98 and 99 -01 R's (Nvious R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nvious R &raquo;</TD></TR><TR><TD CLASS="quote">isnt the steering gear ratio different between the 2 gen's of R's? I believe the 00-01's have quicker steering.</TD></TR></TABLE>
Thats what is says here.
http://www.itrca.com/FAQ/general/changebyyear.php
More Responsive Steering Rack, Ratio Changed to 15.7:1 from the 97/98 16.1:1
Old Aug 25, 2004 | 11:24 PM
Charlie R's Avatar
P.S. Hey Brando you think there will be anything interesting, worth visting this week at the auto show like maybe an R? That would be cool.
evertp1
Feb 8, 2008 05:23 AM
Kojima
Mar 7, 2005 01:31 PM
metal-x
Sep 24, 2004 05:17 AM
93anthracite
Nov 5, 2003 10:13 PM
