Tran Swap
Old Aug 24, 2004 | 10:15 PM
cambopheonix56's Avatar
Default Tran Swap
My 6th Gen Automatic Accord :-( Needs to be swapped over to manual.
what are all the parts I need to Search and where do I search for them????
also what is this project gonna cost me????? thanks
Old Aug 24, 2004 | 11:51 PM
philadd's Avatar
Default Re: Tran Swap (cambopheonix56)
Guide to Basic Accords:
https://honda-tech.com/zerothread?id=797528
scroll down to urbanlegend's second post.
Old Aug 25, 2004 | 06:15 AM
Turbowa's Avatar
I just got done doing the swap in my 99" coupe. To make you life alot easier get a manual tranny out of a 98-02 accord. The mount for the tranny, hydrolic lines, clutch master and slave cyl's are all different from other years. You can us a tranny out of an older model but will have to weld in a braket for the tranny on the pass. side. You MUST use the same year clutch pedal and master cyl., ie- 97 master cyl and pedal assy or 98 and up master cyl and pedal ASSY. Shift cables must be 98" and up. Shift lever can be from either 5th or 6th gen.
fantasya98
Aug 20, 2006 08:41 AM
erck
Jul 2, 2006 11:28 AM
lvblkjack
Oct 18, 2005 07:14 PM
Prelude to David
Dec 5, 2002 03:19 AM
CmptchAV6
Feb 28, 2002 09:59 PM
