Koni Yellows at full soft - damage?
Old Aug 24, 2004 | 10:09 PM
an2ny888's Avatar
Default koni yellos at full soft?
i remember reading that setting the yellows at full stiff will cause premature damage. is the same true if i set it at full soft? i'm using them with stock ITR springs
Old Aug 25, 2004 | 04:06 AM
.RJ's Avatar
.RJ
Default Re: koni yellos at full soft? (an2ny888)
Do not run them at full soft or full hard. Back them off 1/8 turn.
Old Aug 25, 2004 | 04:14 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: koni yellos at full soft? (.RJ)
Suck at full soft, full hard kick ***!
Old Aug 25, 2004 | 06:03 AM
Rene M's Avatar
Yep, i screwed up a set a full hard all the time..
Old Aug 25, 2004 | 06:05 AM
.RJ's Avatar
.RJ
Default Re: koni yellos at full soft? (Rene M)
If you leave them at full soft the adjuster rod can stick. No damage to the shock, but its stuck and you have to send it back to Koni.
Old Aug 25, 2004 | 11:43 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">If you leave them at full soft the adjuster rod can stick. No damage to the shock, but its stuck and you have to send it back to Koni.</TD></TR></TABLE>
I never saw that on mine, I have run them for a year at a time at full soft. Regardless, I'm going to move mine to not-full-soft.
-Chris (sucks full soft)
Old Aug 25, 2004 | 12:21 PM
Rain_man's Avatar
New User
Default Re: koni yellos at full soft? (ccfries)
Did Koni include instructions stating not to do full soft or full hard? If not, they really need to...
Old Aug 25, 2004 | 04:40 PM
an2ny888's Avatar
will set it at 1/8 th turn, tnx for the info
blackEKcoupe
Suspension & Brakes
Jul 3, 2007 07:26 AM
Tippyman
14
Oct 29, 2006 10:21 AM
the soL that could
Suspension & Brakes
Feb 6, 2006 06:27 PM
TegoDC5
May 9, 2005 06:15 PM
taytay333
Mar 26, 2002 03:54 PM
